Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-03-2005, 11:46 AM
Stani2000 Stani2000 is offline
95 Transport Power Window Problem
On my 95 Transport, the driver's side power window will only close part way when the switch is pressed. If I wait a couple minutes and press it again, it'll close a little more. It can take many attempts to close it all the way. What is the likely problem?
Old 08-03-2005, 12:43 PM
LMP's Avatar
LMP LMP is offline
Re: 95 Transport Power Window Problem
The window regulator and window rails have become hard to move and the motor current required to overcome the drag is too high. An electronic sensing protection device cuts the voltage feed out and resets after a while.
YOu should go inside the door and lubricate mechanical components.
It is also possible the protection device has become oversensitive.
www.avigex.ca/xport/door1.jpg
www.avigex.ca/xport/door2.jpg
www.avigex.ca/xport/door3.jpg
www.avigex.ca/xport/pwrwindows.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 08-04-2005, 07:04 PM
Re: Re: 95 Transport Power Window Problem
Thanks for the advice...I'm still having the same problem (both windows now). Can you advise on the "electronic sensing protection device"? Where's it at?
Thanks again!
Stan
Old 08-08-2005, 01:40 PM
LMP's Avatar
LMP LMP is offline
It is built in the motor casing. However, the auto reset breaker at the head of the circuit in the diagram may be the culprit too and this may explain why both motors do the same now. This breaker is in the convenience center
www.avigex.ca/xport/convenience_center.jpg
THere are other similar breakers just beside it and you can swap it for another for a quick check.
Old 09-21-2005, 09:21 PM
66chevelle 66chevelle is offline
I know exactly what the problem is. In these motors, (which are junk from GM parts), is a thermo switch which is to protect the motor from overheating. This will fail prematurely and you think that the motor is bad. If your handy take the motor apart, solder the fuse closed to prevent it from opening the circuit and the motor will work full time. The switch acutally stops the motor when it goes down ( Auto down feature). And no your motor will not overheat, unless you sit on the switch for a hour.
