Old 08-03-2005, 08:38 AM
jpersall jpersall is offline
94 Lesabre Over Drive quits after 30 min.
Has anyone experienced a problem with the over drive not working after being on the road for 30 minutes or so. This time varies and sometimes it will work for a couple hours, but eventually it just stops shifting into over drive.
Old 08-11-2005, 12:08 PM
g8124u g8124u is offline
Re: 94 Lesabre Over Drive quits after 30 min.
has anyone found an answer to this problem??? my mother is having a similiar one.
Old 11-11-2005, 05:09 PM
sturdei sturdei is offline
No answer but mine is doing the same thing. It started happening shortly after the 150,000 mile transmission fluid change. I've tried additives to teh transmission fluid but nothing helps. It will run for just a few miles in overdrive, then drops back to third gear and won't go back into overdrive again until I shut it off and start the engine back up again. I can't help but think it's computer related because of that. Also when in overdrive but running in third gear, when I let off the throttle to slow down, it comes out of gear and the engine idles, regardless of my driving speed at the time. Then when I hit the gas again, it revs up and shifts back into third gear and continues on its way.
