View Poll Results: ???Is It Worth Lifting An S-10??? Or Will It Cause Problems
Yes 2 100.00%
No 0 0%
Voters: 2. You may not vote on this poll
Old 08-03-2005, 06:46 AM
mayville1 mayville1 is offline
Send a message via AIM to mayville1
**Where To Get A Lift Kit**
I wanna put a lift in my s-10 what are some websites i can check out that have nice ones for fairly cheap prices.
Its a 95, reg. cab, and 4WD
Old 08-03-2005, 07:32 PM
OverBoardProject OverBoardProject is offline
Banned
Re: **Where To Get A Lift Kit**
There's a very good quality 2" lift kit from roughcountry here http://rough.roughcountry.com/Chevy_4wdS10_2in.htm
There are higher lift kits (5 or 6") but they are really expensive and way harder to install.
You can also pretty well make a body lift for a very low price, just surf the net
Old 08-03-2005, 08:31 PM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
trail master makes a 4" kit , which requires an exhaust mod and cutting brakets off the frame , BDS makes a 5" , which erquires the same things , and super lift makes a 6" , which also requires the same things , i hear bad things about the quality of super lifts system , and trail master's isnt renowned for thier quality either , but ive heard good things about BDS's lift , all of the above lifts will clear 33's , but the tires will rub , and you will need to trim the bumper , but they will all clear 31 with no mods at all , the kits usually average about 1700$ just for the kit , and to install it will most likly cost over 800$ , and you will never be able to put the truck back to stock height
ive never been fond of body lifts , simply because they screw with all your linkages , especially if you drive stick , but other then that , brake lines , fuel lines , can all suffer from this , most importantly , your steering column angle
