Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-03-2005, 01:42 AM
partyup840 partyup840 is offline
Send a message via AIM to partyup840 Send a message via MSN to partyup840 Send a message via Yahoo to partyup840
Angry Ok whats going on here!!
Ok I got a 93 prelude si. When i go out to drive around after awhile if I come to a stop the thing just shuts off. I think I might be burning rich as there is black soot on the end of the exhaust but I have no idea if there is a way to change the mixture on this thing. Also there are no trouble codes going off so I am lost. Any input would be appreciated...
Old 08-03-2005, 02:02 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Do you have any mods?
Old 08-03-2005, 11:36 PM
No not yet I want to fix this first.
Old 08-04-2005, 10:22 AM
Icebox's Avatar
Icebox Icebox is offline
Send a message via AIM to Icebox Send a message via Yahoo to Icebox
Re: Ok whats going on here!!
So you're saying when you come to a stop at a light, for example, the car just stalls out...?
1990 Honda Prelude Si 2.1
My Baby....
Old 08-04-2005, 03:57 PM
Yeah it will just sputter then shut off. It does it even when I go to park...
Old 08-05-2005, 12:48 AM
fbomb77 fbomb77 is offline
i had the same problem in a 93 geo storm. sometimes it was hard to get the fuc@er started again. the problem i had was with the ignition module, a 25$ part(for the geo at least..). hope this helps.
Old 08-05-2005, 09:45 AM
hondaprelude88 hondaprelude88 is offline
Any Codes from the ECU the check light on? If so check that out it may lead you somewhere.
Old 08-05-2005, 11:55 AM
Icebox's Avatar
what's it idel at? if it idels really low, you might have to just turn the idel up a little bit...
Old 08-05-2005, 01:27 PM
Re: Re: Ok whats going on here!!
No there are no codes I already checked. According to the ecu everything is fine LOL
Old 08-05-2005, 01:28 PM
Actually it idles high right now 1200 so Im still lost. When it shuts off it gives up done sir done.
Old 08-05-2005, 08:47 PM
Icebox's Avatar
? done sir done? 1200 is really high, turn the idel down...it should only run like 700-1000 if that...
My Baby....
Old 08-06-2005, 12:05 AM
I know the idle is high but what about it shutting off
done sir done is some usmc terminology sorry about that
Old 08-06-2005, 05:51 PM
Icebox's Avatar
It just shuts off when you come to a stop..at any point in driving...? that seems really odd....hmm..have to think this one out..post in a bit.
Old 08-08-2005, 12:02 AM
rgreene414 rgreene414 is offline
Send a message via AIM to rgreene414
i had a problem like that too. mine was the throttle body. it was clogged so i cleaned it and the problem was gone try that out and let us know
Old 08-08-2005, 12:05 AM
alphalanos alphalanos is offline
Check air and fuel filters, plugs, cat, TB.
96 EJ6. Future home of boosted B18C1.
