Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-02-2005, 11:55 PM
Benag Benag is offline
Turning up the boost.
I have a question about the T25 and a boost controller. One of you guys said you turned it up until it went bad. So is turning up the boost on the turbo not bad for the engine (assuming you aren't being ridiculous with it) ?
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 08-03-2005, 12:23 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Turning up the boost.
The concensus is 16psi on the T25. It's not a matter of being harmful to the engine, but that the turbo is inefficient above there are produces a lot more heat than power. The heat will knock on pump gas.
Old 08-03-2005, 01:30 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You might run into fuel-cut as well.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-03-2005, 03:47 AM
Whathits14 Whathits14 is offline
fuel cut is not pretty......
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 08-03-2005, 05:19 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
You shouldnt hit fuel cut on your t25 at 16psi. Go for it, but be sure to watch your boost gauge.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 08-03-2005, 12:26 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Re: Turning up the boost.
You shouldn't hit fuel cut on your t25 at ANY boost. I mixed a little 110 octane in my tank back when I had the t25 and ran it to ~21psi. I felt no difference in pull and guess what, NO FUEL CUT That turbo just can't dish out enough airflow. Nuff said
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 08-04-2005, 08:08 PM
JoeWagon's Avatar
Banned
I seemed to hit it when the boost went past 22 at low rpm. Remember fuel cut is grams/rev airflow limit.. so when the RPM are lower, it's more likely. T25 spools fast. No matter though, don't kill the turbo by doing that often, even if you have race gas to counter the knock.
Old 08-07-2005, 11:34 PM
So running at high PSI is only bad for the turbo besides the knock. So running at 16 PSI isn't bad for the turbo just uses more gas? And I suppose that running at like 22 psi for too long will warp the turbine or compressor wheel?
'95 Eclipse GS-T
5-Speed
Old 08-07-2005, 11:38 PM
alphalanos alphalanos is offline
just keep it conservative. if you know something might happen, it probably will. dont push it to the limit, if you want to run alot then get better parts.
96 EJ6. Future home of boosted B18C1.
