Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-02-2005, 10:36 PM
confusedperson confusedperson is offline
Washer Fluid Tank Not Working
The washer fluid used to work in my 4.6 1995 tbird but all of a sudden it just stopped working. The washer tank is full, so I know there's no leak. Is there a way I can fix it? Thanks!
Old 08-02-2005, 11:18 PM
coondawg6 coondawg6 is offline
replace the $15 pump its on the side of the washer bottle
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-03-2005, 12:08 AM
KimMG KimMG is offline
AF - Advisor
Re: Washer Fluid Tank Not Working
Test to see if you are getting power to the pump.
Make sure the electrical connections are clean and secure.
Make sure if there are any filters/screens that they are clean.
Make sure that the tubing is not clogged.
Although not always the case, pump failure is the common fault for the symptoms you have described.
Old 08-03-2005, 12:35 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Might sound stupid, but make sure the idiot (in case it was you, replace "idiot" with "person") that filled it last didn't drop the cardboard seal from the washer fluid jug into the reservoir. My ex did that on my first '93 and it took a new pump and almost a 2nd one before I figured out that little seal was getting sucked up against the pump and not allowing fluid to pass.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-03-2005, 11:05 PM
Re: Re: Washer Fluid Tank Not Working
[quote=flewthecoupe]Might sound stupid, but make sure the idiot (in case it was you, replace "idiot" with "person") LMAO you are hilarious flew
Old 08-04-2005, 12:48 AM
Well, my ex was an idiot.
Old 08-04-2005, 04:16 PM
LOL! Well I'll go ahead and test for all that, if that doesn't work I'll just go ahead and buy the pump, good thing it's not too expensive. Thanks.
Old 08-10-2005, 02:21 AM
intrcptrbird intrcptrbird is offline
Send a message via AIM to intrcptrbird
Are the wipers working when you push the button? Cause if those arent then you're gonna need a new switch. Thats the case with mine and I decided that they really arent that important right now.
