Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 08-02-2005, 10:21 PM
shadow-racer shadow-racer is offline
Send a message via AIM to shadow-racer
engine leaning out
How would you keep the engine from leaning out as the temperature raises in my 93 shadow, with an 89 caravan engine in?
Old 08-02-2005, 10:26 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: engine leaning out
you can change your oxygen sensor, that's most pratical. A used car salesman's trick is to jump the throttle body temp sensor and make it run rich, but I'd go with the oxygen sensor first before you start fooling the computer with faulty signals.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-03-2005, 08:45 AM
Re: Re: engine leaning out
Well you see, it is for a racecar. And I have heard that when at WOT, that the 02 sensor is ignored, and a pre programmed code then sets the amount of fuel being poured in the engine.
Old 08-04-2005, 10:07 PM
you are correct, have the programming checked out or better yet just disconnect the oxygen sensor, the computer will go into "limp mode" that is, it'll go into constant open loop thus giving you a rich condition at all times.
Old 08-05-2005, 08:08 AM
I have already tried it without the oxygen sensor plugged in, and it still runs lean. Now, the water temp sensor (the one that plugs into the gooseneck) I plugged that hole and have the sensor hanging in a cool place, trying to trick the computer to giving it more gas. I dont care about unplugging sensors either, as long as it still runs.
Old 08-08-2005, 12:01 AM
you could unplug your MAP sensor as well and send it into limp mode. It's not the best but it's a 50/50 shot, disconnect your TPS, it'll run rich then, though the downside is that it might stumble and run like crap.
