Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-02-2005, 09:09 PM
mjwilliams3434 mjwilliams3434 is offline
99 Olds Silhouette code P1483
Can anyone tell me what this code means?
Old 08-02-2005, 10:32 PM
GregA's Avatar
GregA GregA is offline
Re: 99 Olds Silhouette code P1483
This is what my manual says (some from the manual, some in my words):
P1483 = Engine Cooling System Performance
Code is set when the PCM "thinks" the coolant temperature (measured using the ECT Sensor) is higher than it should be (based on calculations). Variables involved in the calculation are Intake Air Temperature, Engine Load, Engine Speed, & Vehicle Speed.
This code may not turn on the check engine light.
Most likely caused by a cooling system problem.
Check cooling fans, air flow through radiator, Engine Coolant Temperature (ECT) Sensor, etc.
Hope this helps some.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
