Old 08-02-2005, 08:49 PM
goofy4467 goofy4467 is offline
88 lesabre one coil is not firing
I have a 88 lesabre with a 3800 motor and 1 coil out of the 3 is not firing.
It has power to it so I replaced the pack and it did not fix it the problem.
There is no spark out of the coil.
Is it the module?
The crank sensor?
or?
Old 08-02-2005, 09:25 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 88 lesabre one coil is not firing
Did you switch a known good coil, with the one that is not firing? Try that, it could be a loose connector underneath.
Old 08-02-2005, 09:42 PM
yes I put the new one in and even rechecked the connections after it didnt fix it
Old 08-03-2005, 10:45 PM
HotZ28's Avatar
AF Moderator Elite
Will the car start on the other two coils? Got any codes stored? Could be the ESC module.
