Old 08-02-2005, 07:56 PM
blkmonday's Avatar
blkmonday blkmonday is offline
front end play
my wife has a 95 2dr blazer ls 4x4. a few years back she was in a slight fender bender and a car hit her drivers side rim. we had the front end aligned and other than a scratch on the rim the trucks been fine. i noticed recently a grinding noise in the front end at slow speeds (not using brakes) i pulled off the right side tire and found the resistance to be a little tight (spinning the wheel in place). the brake pads looked worn but not horrible and the rotor seemed fine. i noticed some excessive play in the front end when i moved the tire from left to right..about an inch to inch and a half. is this acceptable? if not what is worn? i raised the other side and had the same play and resistance while turning the tire. except on this side i hear grinding. this is the side that was hit. it got dark outside so im gonna look better tomorow. any ideas what the problem could be and what i should look for? thanks in advance
Old 08-02-2005, 09:59 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: front end play
Use the search feature and look up bearing & Hub. This topic has been spoken about in detail.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 08-03-2005, 01:35 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: front end play
That or the differential is partially engaged, get this looked at ASAP by a mechanic.
1995 Factory Blazer Service Manual for sale, PM if interested.
