Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-02-2005, 04:41 PM
dcadiman dcadiman is offline
Simple R12 to R134a conversion
I just found the cheapest and easiest R12 to R134a conversion kit. I paid $33.00 plus tax at Walmart.
The kit comes with:
* "How To" CD
* Metal can tap valve & fittings
* Charging hose with color coded in line pressure gauge with high impact nylon Quick Connect. Charges and measures in one step for accurate charging of an R-134a air conditioner.
* 3 service port adapters with protective caps for all cars 1976 and up, including special GM Systems 1991 and up.
* Retrofit label
* 3 can of 15 oz. High Mileage Refrigerant & Oil (12 oz. of Refrigerant and 3 oz of Ester Lubricant per can with High Mileage Anit-Wear Additives and "System Safe" Leak Sealer for all rubber leaks
It is called the EZ Chill retro and recharge kit. I installed it in my Lincoln today in less than 10 minutes (after the R12 was evacuated). The cool thing about this system is you cannot get it wrong. The high and low side fittings only fit on the correct connector.
My A/C blows nice and cold now. If you have an R12 system get this kit and do it yourself. I have been quoted between $120.00 to $150.00 to have my system converted professionally. I saved about $100.00 this way.
I now return you to your regularly scheduled posts......
1995 Jeep Grand Cherokee Laredo (stock)
1989 Lincoln Town Car with:
High flow cone air filter
True catback dual exhaust
Turbo mufflers
