Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-02-2005, 03:47 PM
Ambassador7 Ambassador7 is offline
Send a message via AIM to Ambassador7
90 Accord serious starting problem...please help!
90 Accord serious starting problem...please help! (Post #1)
My car has been having trouble lately. First went the VSS and honda wanted $600-700 to fix it along with my main relay. I replaced the VSS for only $40 (ebay cost). However, I am thinking now that my other problem was not the main relay...even though most forums have led me to this guess. Here's what is happening:
It starts and runs perfectly, but when I leave it out in the sun....specifically out in the sun and it gets all hot inside...it will turn over easily but won't fire up. Ocassionally when this happens it will start and then quickly cut out and then I'll have to wait a while till it cools off and it will start. Or if I would hook up cables to it the car would start. The honda tech said this was because it would then give it enough "juice" to power the fuel pump. So everything pointed to the main relay but I took it out and tested it and it was fine. All the solder points were fine. So I drilled 4 holes in the housing to help it vent just in case and put the relay back in.
Then just today I was driving with cruise on going about 65mph and the cruise light went off and the speedo started descending. That's when I realized that the engine just cut out! It won't start! It makes a totally different noise when trying to turn over. It sounds a lot weaker, however I do here the relay click and the fuel pump turn on. It makes a weak attempt to start with a sort of clicking noise.
What could this be? (searching says that it could be the coil, ignitor, or ECU?) Keep in mind that nothing has been done to fix the original starting problem when it gets hot from the sun. And now this? Could they be related? Anyone have this happen?
Chris
Old 08-02-2005, 04:15 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 90 Accord serious starting problem...please help!
it sounds like the battery is weak causing it to slowly turn over? that sound like and alternator... test to see if youre getting spark...
Old 08-02-2005, 04:23 PM
ok...pretty sure my battery and alternator are fine
about to go test for spark
Old 08-02-2005, 04:27 PM
Kind of a Big Deal
then check to see if youre getting spark.
Old 08-02-2005, 09:23 PM
ok i checked to see if i am getting a spark and I am NOT getting a spark. I also noticed that the plug wires are pretty coroded on the inside there by the distributor? Could that be it, Or would it most likely be the coil and or igniter?
also, what else would be affected by the sun that would temporarily prevent power to the main relay and thus to the fuel pump?
CHECK OUT MY CAR Before & After
Old 08-02-2005, 09:55 PM
Kind of a Big Deal
ok, id do a tune up first... maybe your dizzy cap and rotor are fried...if your still not gettting spark, check to se if the ignitor is bad (i cant remember off hand how, but you need a multimeter)
Old 08-03-2005, 02:38 PM
my plug wires were coroded so i replaced them along with a tune up and new rotor and cap...still nothing.
looking in to how to check ignitor
Old 08-07-2005, 05:30 PM
still no spark...anyone?
Old 08-08-2005, 07:14 PM
update:
i got a honda service manual today in the mail (ebay) and did the igniter test. i am pretty sure the coil is good and the igniter unit is not. this is what could be preventing spark right? the manual isn't clear but that would make sense. also, could this affect the main relay at all? (wondering if they are related problems). i put my buddy's working relay and a junkyard relay and they all act the same in my car...also his started with my relays. but he was just visiting and i can't get his car again to try out the module.
any other comments or ideas?
Old 08-08-2005, 07:50 PM
Kind of a Big Deal
congrat on finding the problem, change the ignitor and see if it still acts up.
Old 08-09-2005, 09:38 AM
-should that camshaft end where the distributor joins spin when i try to start the car? because it is not and someone suggested to look at that. possible timing belt? would this give me no spark?
Old 08-09-2005, 12:19 PM
Kind of a Big Deal
yes, when u try to start the car, the cam should spin, therefor spinning the dizzy, if the dizzy doesnt spin, no spark... possible timing belt, or worse, broken camshaft. also, in either case, make sure you didnt bend or break any valves.
Old 08-09-2005, 02:38 PM
went in and found the snapped timing belt...which explains the slight vibration i heard there weeks before it went. i also have a little bit of clear green fluid dripping but its not bad. its coming from above the rear balancer belt pulley. i think i remember seeing this before it broke though. the honda dealer said i probably didn't bust any valves. i am in the process of replacing the belt now...this manual is nice. any help checking these valves, location of water pump, and anything else needed while this is all open would be appreciated.
thanks.
chris
Old 08-09-2005, 03:07 PM
Kind of a Big Deal
replace your water pump while your in there, cuz the removal of the timin belt is needed to chage it anyway. and the greenish fluid is most likely coolant, which is prolly your water pump.. and trust me youll know if you bent valves when u start it up for the first time.
Old 08-09-2005, 03:31 PM
thanks man...let me get a movin' :o)
