Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-02-2005, 03:06 PM
BigLoser BigLoser is offline
Exclamation 93 Cutlass Problem - Im Broke
Probably a simple question, but i started my 93 Cutlass Supreme the other day (150k) and it revved up 3k-4k rpm on its own and wouldnt go down to idling. put it in reverse and it floored itself out of the lot. brake was very jammed and practically impossible to stop. definitely not driveable right now. please help
Old 08-02-2005, 03:17 PM
Jeremy86 Jeremy86 is offline
Send a message via AIM to Jeremy86
Re: 93 Cutlass Problem - Im Broke
I don't know what it might be, but good luck on figuring it out.
Aka 93 Cutty
Working on my next project: A 1986 Honda CRX. Little beater with lots of engine
Car Audio Freak
http://www.sounddomain.com/ride/613185
Old 08-06-2005, 01:45 AM
OldzCutlass90 OldzCutlass90 is offline
Send a message via MSN to OldzCutlass90
eh
im having the same problem it revs up when i start it up and after like 10 minutes it lowers down i cant drive mine either for atleast 10 minutes or ill be hitting someone i wish i knew what it was
Old 08-06-2005, 01:05 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Two things to check, Mass airflow sensor may be dirty or you have a vacuum leak. Most common cause of runaway idle.
Old 08-08-2005, 08:39 AM
65comet's Avatar
65comet 65comet is offline
Mine had that problem also and it was a vacuum leak, more precisely, it was the intake manifold gasket had a leak. Try tightening those bolts just a little, never want to over tighten them, and see if that helps some. If there is any improvement, then new gaskets may be in order. The chevy dealer down the road found the problem for me, I had thought it was computer related and it hadn't crossed my mind it might be as simple as vacuum. He said that the gasket going bad was more common on the 3.4L than just a vacuum hose going bad. Since I know the guy, he only charged me the time it would have taken to diagnose a vacuum line and let me buy a less costly gasket set at the parts store. Said they normally charge 3 to 4 hundred to fix it. Then he put the gasket on after hours.
Old 08-08-2005, 10:44 PM
Jim Adams Jim Adams is offline
take some carb cleaner and spray it around your intake and all vacuum lines and it will pick up idle when you get to the leak ,,if it idles to high to find the leak then use water and it will dye down when it comes to the leak ,,but it sounds like you may have a bad IAC motor Idle speed controller,,,check it for codes,,also when you put it into reverse and you have a bad motor mount it will make then engine lean foforward and pullon the throttle cable making it have even more throttle.
Old 08-10-2005, 08:54 AM
94cutlatized 94cutlatized is offline
Send a message via MSN to 94cutlatized Send a message via Yahoo to 94cutlatized
93's have a mass air flow?
Old 08-12-2005, 01:16 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
also check the cable. I've had the cable stick , and have seen it Off ot's track causing this too. but does sound like MAF or TPS. Try unpluging them one at a time and starting it up. sometimes it will stop the trouble if the bad parts unhooked. Good Luck
94cutlatized 86' have MAF \,,/
