Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-02-2005, 08:40 AM
jpwheeler jpwheeler is offline
1998 Ram 1500 5.9L Slow Start
Last couple of days, I've noticed when I go to start my truck it takes about 5-8 seconds for the engine to finally start. It use to just start right up, It doesn't turn over slowly, it cranks at the normal speed, so i doubt battery or connection is the issue here. If anyone gots any advice on this, it be helpful. Not sure exactly where to start with this. Thanks
Old 08-02-2005, 09:21 PM
sharter sharter is offline
Re: 1998 Ram 1500 5.9L Slow Start
It sounds as if the ignition system is giving trouble. Coil maybe or the rotor. Or maybe the distributor cap. I would have it checked.
Old 08-04-2005, 11:02 AM
1998Ramtuff's Avatar
1998Ramtuff 1998Ramtuff is offline
I hope you don't have what I am still fighting. My 1998 Ram 1500 5.2 does the same thing. Hard to start, cranks fine just takes longer to get the thing running. I also have an intermettent "Check Engine" light from time to time which is the P0300 ( Multiple missfire code). Here is a list of what I have had changed to date:
1. Cap, Rotor, Spark plug wires, spark plugs.
2. Ignition coil
3. Camshaft sensor
4. 2 ea fuel injectors (#4 and #8 cylinders)
5. Dealer changed the intake manifold gasket
6. Catylitic Converter
7. 2 ea O2 sensors
8. Complete fuel injector system flushing and cleaning
9. Gas Cap
10. ?
Old 08-04-2005, 11:30 AM
HansonHVAC HansonHVAC is offline
Send a message via AIM to HansonHVAC
My father in law had the same problem it was his fuel filter.
Old 08-04-2005, 12:50 PM
Thanks for you help you guys, I have an idea its the ignition, I've tried the 15 second on wait for your fuel pump to repressurize and same thing, so my hope its the small ignition components, I'll post back with the results! Thanks fellas
