Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-02-2005, 12:49 AM
GTPWarrior's Avatar
GTPWarrior GTPWarrior is offline
trouble with shifter
Okay I have a 98 GTP Having problems with getting out of park
Will still come out after a little foreplay but have seen on here before about this problem. Any old school members remember. Please Point me in the right direction/
[b]1998 Pontiac Grand Prix GTP
"A man walks into a bar and says.....................*ouch*"[/b]
Old 08-02-2005, 08:43 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: trouble with shifter
It sounds like a BTSI problem. Most likely the shifter assembly and shift lock solenoid.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-17-2006, 09:12 AM
2000GPGTBlue2dr 2000GPGTBlue2dr is offline
I had the same problem with my 2000 GT. Guess what??? Here's what is wrong. I replaced the shifter ($250) thinking it was the solenoid attached to it, and the P R N D 3 2 1 lights on the dash still kept flickering, and the key would not release out of the ignition when I put the car in park...
There's a 10 amp fuse for the BTSI (see your owner's manual) which is the Automatic Transaxle Shifter Module. Believe it or not sometimes the fuse doesn't make contact with the fuse housing causing an intermitent connection that causes the BTSI that controls or signals the solenoid near ignition that the car is in park thus releasing the lock to work "off and on."
So here's what you do.... Take that fuse out clean it off, and then actually bend the 2 pieces of metal sticking out of the fuse in opposite directions so that when you put the fuse back in, it ensures a stronger connection to the pieces of metal inside the fuse housing. I did this and the lights no longer flicker, and everytime I have the car in park I can shift to other gears, and I can release the key out of the ignition.
Old 07-17-2006, 09:44 AM
BNaylor's Avatar
2000GPGTBlue2dr,
Do not resurrect old threads this old. Also, I counted at least 8 other posts on similar issues. At this point what you are doing amounts to spamming, post whoring and violates AF forum rules.
Although your fix helped you it may not be the fix for other members and the solution varies among model years. BTSI problems are not just related to the BTSI fuse.
This is your only and final warning.
Timeslip 08/12/06
Closed Thread
