Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 08-02-2005, 01:40 AM
Moriah Moriah is offline
Question Mercury Mystique Mess
[color=indigo]I have replaced the alternator, sensors, filters, oil, spark plugs, battery, spark plug wiring, I did the compression test { three times once with adding oil}
Spark Plug
#1 185 PSI
#2 200 PSI
#3 190 PSI
#4 190 PSI
Haynes repair manual isn't helping will still not start, turns over and is almost there even when hooked to another battery, Please any suggestions money tree in the back dried up.
Old 08-02-2005, 09:27 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
have you replaced the crank position sensor?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-02-2005, 01:57 PM
Re: Mercury Mystique Mess
No I didn't looking for one now thanks!!
Old 08-11-2005, 06:38 PM
Spark Plug
#1 185 PSI
#2 200 PSI
#3 190 PSI
#4 190 PSI
O.K. new question when you do a compression test how do you know if you need piston rings or the pistons themselves that are bad ?
Old 08-11-2005, 08:09 PM
the psi in the blown cylinder would be a lot lower than the good ones.
"The CEG Nazi"
www.contour.org
Old 08-12-2005, 05:19 PM
Thank you again so it is only the rings then? now my battery is getting to much power and I am trying to find the source of the sparking, but you have been really wonderful and helpful thanks again.
