Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-01-2005, 10:57 PM
fbomb77 fbomb77 is offline
Lude speakers
How the hell do you get the front door speakers out?? I tried to pop off the grill but i think i'm breaking it so i stopped. Do i gotta get the door panel off? My 1st Prelude. Also will 8 inch subs fit in the back window?? Thanks.
Old 08-02-2005, 09:22 AM
cas4067 cas4067 is offline
Re: Lude speakers
Well you have to take the whole door panel off. That sucks be carefull taking it of to I broke the plastic thing that goes around my door handel when I did it. Once again it sucks..
check it out let me know what you think
my ride
Old 08-02-2005, 04:02 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: Lude speakers
Like stated above, the door panels must come off. If you're putting full range speakers in, it's recommended you disconnect the tweeters so that your imaging isn't thrown off, unless you're putting a component system in. I've thought about putting a cheap 8 inch sub in the back, but between the two seats where there is one already, I don't know if that's what you're talking about. If not, you can put a sub whever you want as long as you build a box for it. If you're talking about cutting a hole and putting it on the rear deck, make sure it's a free air sub.
Old 08-04-2005, 01:04 AM
Re: Lude speakers
Thanks, i thought maybe take the panel off. WTF kinda BS is that? Ok let me get this straight... there is a sub between the rear "seats". I see the two speakers in the rear window and can see them from the trunk..but i havent noticed a sub. i have a 94 si. how would i access the speaker between the rear seats? whats the deal with this imaging with the front tweets?? Thank fellas...
Old 08-04-2005, 01:55 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: Lude speakers
The sub only comes in the VTEC and SE Preludes. Its an Alpine 6x9. You can access it through the trunk. As for the imaging; When you have two things convering the same frequency, it tends to ruin things.
Here's a picture of the sub in my car: http://s94031292.onlinehome.us/images/Image015.jpg
