Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-01-2005, 10:25 PM
hotrodrick hotrodrick is offline
spark plug replacement
I think I need to replace the spark plugs on my 1999 Ford Crown Vic. I recently bought this car for my son and have recently noticed a slight miss during loaded conditions. During idle or light loaded conditions, it seems to run fine. Since I don't have any record of the maintenance, I thought spark plugs would be a good place to start.
While I have a considerable amount of mechanic skills, they are limited to either older automobiles or GM products. Any helpful hints would be greatly appreciated.
Rick
Old 08-01-2005, 10:58 PM
BiggerJon BiggerJon is offline
aluminum heads. get motorcraft plugs. gap to .054". coil over packs are easy to remove. inspect boots. you do not have to remove the fuel rails. use just a dab of antiseeze. torque to 12 ft/lbs.
Mods
Old 08-02-2005, 05:08 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
theres nothing to this job just always even tell your son if he works on it use only motercraft or autolite plugs wires are of your choice but always moter craft or autolight as far as plugs hope this helps and good luck
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 08-04-2005, 01:25 AM
benk518 benk518 is offline
Cool check plugs might be coil pack
if one plug seems fouled down or out it may be the coil pack, had this problem replaced all plugs then had to go back and find coil pack that caused the problem.
