Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 08-01-2005, 08:55 PM
4cylinderbomber 4cylinderbomber is offline
90 B2200 vacuum diagram 2.2L
Hello, Does anyone out there have a BIG vacuum diagram for a 90 B2200 with a 2.2L? I saw the post that "BadassRx-7 posted a while ago, helpful if you have a 2.6L. I have a 2.2L. I have the Chiltons manual that has the same diagram as "BadassRx-7" in it. I'm not sure what the differences if any there are between the 2.6 & the 2.2, but I would think if there wasn't any Chilton's would have put "vacuum diagram for 2.2L and 2.6L" Also does a 2.2L have a "mixture control valve"? If so, where is it? The 2.6L has it right in front of the carb, towards the passenger side. I don't see anything on mine that looks to be a control valve. Any help would be great. [email protected]
Here are the posts from "badassRx-7", in case you need them.
http://files.automotiveforums.com/ga...00vac00150.JPG
http://files.automotiveforums.com/ga...code75-med.JPG
Old 08-04-2005, 01:22 PM
Bach4660 Bach4660 is offline
I will try emailing you the vacuum diagram, I found this one to be accurate for my '91 B2200. As for the fuel mixture, it is on the passenger side of the carb, in the middle, and it has two circular holes one above the other, but there is a tamper proof pin in front of the mixture screw which is the lower hole. You will need to remove the carb, turn it over and drive the pin out with a punch.
Old 08-04-2005, 06:11 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
Factory Vacuum Diagram
Owner of Mazdatruckin.com
