Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-01-2005, 08:52 PM
D-Bo's Avatar
D-Bo D-Bo is offline
overheating
alrighty so its been crazy hot here lately, upwards of 40 degrees C or upwards or 90 F.. and i was parked at a coffee shop this afternoon and suddenly my coolant came barreling out of the overflow container.. so i thought maybe its my thermostat.. so i got a little bit of ice and water, threw it in after turning the car off and then once it was at normal operating temp, i started it again, cranked the heat and drove the piss out of it for 2 minutes.. now its ok and the temp needle is stable. my question is this: should i replace the coolant? should i replace the thermostat? i'm not too worried if i have to do either cause they're both things i can do myself.. any opinions?
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 08-01-2005, 09:45 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: overheating
any air bubbles in the coolatn line? Jack the front of the car up and let it run with the radiator cap off.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 08-02-2005, 09:08 PM
leestewart's Avatar
leestewart leestewart is offline
Re: overheating
Changing the thermostat probally wouldn't hurt
1990 Nissan 240sx Coupe
-SR20DET engine & Tranny
-Nismo motor & tranny mounts
-Apexi Super AFC -Spec Stage 2 clutch
-Greddy Profec B Boost Cont. -14" electric fan
-Autometer Boost & EGT guages
-Walbro fuel pump
-HKS FMIC
-HKS BOV
-Tein Drift Spec coilovers
-Advan Wheels SA3
Future Plans: Stock S-15 injectors and turbo
Hopefully somewhere around 300rwhp!!!
Drive her and have fun fun fun!!!
Old 08-03-2005, 10:13 AM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
yea...
This happened to my friends 240 but its upwards of almost 110 here. We let it cool off for a little bit hopped back in the car. And I drove it home since hes not so great at 5-Spd. Well on the way home it rose to like less then 1 bar away from the 2 white solid ones. What is the Mixture ratio of Antifreeze and water? Is there anyway we can find out if its the Thermostat?
Old 08-03-2005, 03:41 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: overheating
Damnit... Like every thread I see now reminds me of something I need to buy...
I need a Billion Thermostat.
Old 08-03-2005, 04:02 PM
240SX Guy
Re: overheating
Usually coolant shoud be %50 of each. But remember, antifreeze is just that. Anit-Freeze. Prevents freezing. So if you live somewhere where it doesn't get cold very often, use more water and less antifreeze. Water dissipates heat much better.
-Cory
12.6@122mph
Old 08-21-2005, 02:56 PM
Waltz's Avatar
Waltz Waltz is offline
Re: overheating
Hummm , *nissanfanatic* thats partly true , the coolant
has chemicals activated by water , and also disolved by water , if you dont live in a *hell freezes over* area , 50/50 coolant/water is the best option because water boil's at a much lower temperature the coolant . And to aswer some question , a thermostat thats stuck's closed will cause overheating its a cheap part , replace it if possible
Best ofr luck to all
