Old 08-01-2005, 08:17 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Shift Faster
Hey all,
I've been driving and Im not liking the way it's been shifting lately. I've got the short shifter and plastic shifter mounts. But, when shifting, it doesnt fall into gear like it should. I've been grinding into second when shifting fast. Also, i miss 3rd if Im really shifting fast. IDK what the problem is. Shifter fluid? Anything else?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-01-2005, 08:29 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Shift Faster
just think when your trying to shift fast, thats usually my problem sometimes but i never grind gears often or badly just a little noise
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-01-2005, 11:28 PM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
Re: Shift Faster
maby your linkage is bad??
or somthings wrong with your tranny?
i know that it always feels like im hitting an extra "bump" on the way into a gear when i shift so even when im shifting fast and hard i still cant shift quiet as quick as i should be able to.
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 08-04-2005, 03:11 AM
i1nk83 i1nk83 is offline
Send a message via AIM to i1nk83
Re: Shift Faster
my guess is that you will be in the market for a tranny here pretty soon. mitsu trannies dont like powershifting/shifting very quickly.
1990 mitsu eclipse gsx
16g
550's
burned eprom chip
2g mas
3" turbo back custom exhaust
port&polished head, turbo, exhaust mani
mml headgasket
b.s. elimination
centerforce df2
unorthodox crank pulley
autometer boost , a/f
hallman es mbc
homemade fmic and piping
relocated battery lower in engine compartment
purty candy red valve cover
stripped interior
couple of random guages
man this is a big list of nothing special......gotta work on that
50trim in the works
Old 08-04-2005, 03:32 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Re: Shift Faster
I think (at least on the turbo cars) that the clutch pedal can be adjusted because it doesn''t always fully engage. It's on VFAQ or tuners or dsm.org or something.
tedX
I'm>everything
Old 08-08-2005, 08:03 PM
zeus999 zeus999 is offline
Re: Shift Faster
stronger clutch and fly wheel
Old 08-08-2005, 09:59 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Shift Faster
check your clutch fluid to make sure its disengaging the clutch the whole way. also make sure your pushing the clutch in far enough thats usually my problem when i try to shift fast.
PS sorry about the pics. i have them on a cd that i can still send you but they turned out really blurry and shittylike.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-09-2005, 01:33 PM
david-b's Avatar
Dave is THAT guy
Re: Shift Faster
Ahh, its all good.
Yeah, cluytch is going all the way.
Now, I have the worlds fluffiest clutch. Some poeple like, others dont. You dont know when its disengaged when pressing the clutch. It's super soft. I think that's my problem. Can I fix that. Seriously, I can push it down with 2 fingers, all the way to the floor. I've driven my boys STi, and that shit is stiff. I think tha's the problem.
75 Monte Carlo
Old 08-09-2005, 08:37 PM
Re: Shift Faster
sounds like either your slave or master cylinder is bad.
-1stGenRocks-
Old 08-10-2005, 11:43 AM
david-b's Avatar
Dave is THAT guy
Re: Shift Faster
So, what exactly are we talking about then with the slave and master? How can I find out? Does it make the clutch soft?
75 Monte Carlo
Old 08-10-2005, 11:55 AM
Right Said Fred Right Said Fred is offline
Banned
Re: Shift Faster
And after reading this thread I now know how people die in bath tubs with hair driers.
You people are so misguided.
How would a gear grind be a master or slave cyl?
Shifter fluid? OMG (Remember to breath in between breaths.)
stronger clutch and fly wheel? Are you potty trained too? Jesus.
Old 08-10-2005, 11:59 AM
david-b's Avatar
Dave is THAT guy
Re: Shift Faster
That's why I asked. Think about it.
75 Monte Carlo
Old 08-10-2005, 09:51 PM
Re: Shift Faster
master or slave would be because when they dies they usually leak fluid and make it so when you press the clutch down all the way it is really only disengaging the clutch about halfway.
basily your clutch system is like this
you press the pedal
this pushes a rod into the master (or pulls it out i forget but it doesnt matter)
the master sends fluid through the lines to the slave
the slave rod pushes out against the clutch fork
the clutch fork is on a pivot so the other end pushes against the throwout bearing which is against the clutch pressure plate.
-1stGenRocks-
Old 08-10-2005, 10:41 PM
Black97GST Black97GST is offline
Re: Shift Faster
i have the same exact problem, my clutch is very soft, i dont think i can push it in with two fingers though, but i have replaced, Clutch master cylinder, clutch fluid lines, slave cylinder, and i have a new clutch and fork (b/c one of the fork rods "broke" supposedly at least thats what they told me). thats preaty much everything that you can replace on a clutch lol and my clutch it still soft, i dont really think there is much you can do about it except for adjust it, if you have the same problem, b/c i thought it was my clutch master cylinder also and i turned out it wasnt at all, and its like 90 dollars, so thats money down the drain, but i SHOULDNT have to replace it again, so if any one needs a clutch master cylinder, or slave cylinder that both work fine (my old ones) let me know
Old 08-10-2005, 10:50 PM
Re: Shift Faster
make sure they bleed it well. 2g's have trouble sometimes getting all the air out and that will make a soft pedal too
-1stGenRocks-
