Old 08-01-2005, 09:04 PM
nscrfn's Avatar
nscrfn nscrfn is offline
Fuel Pump resistor
is the resistor a dealer only item?I have called a few parts stores and they don,t have them.
Injection is nice But,I'd rather be B L O W N
Old 08-02-2005, 09:20 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuel Pump resistor
Normally, yes. But you can get the kit here too:
http://www.pfyc.com/store/merchant.m...ER&AFFIL=yfeed
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-02-2005, 11:48 AM
dmasjz45 dmasjz45 is offline
Re: Re: Fuel Pump resistor
or you could get the ones on ebay that claim 20 hp :-P
Old 08-02-2005, 12:19 PM
BNaylor's Avatar
Re: Re: Re: Fuel Pump resistor
??????? Hey dmasjz45, just thought I'd let you know and clarify if anyone is confused that the fuel pump resistor this guys looking for is not one of those bogus mods. He might need it because his fuel system isn't working properly. The GTP has a two speed fuel pump. When the resistor goes bad the fuel pump either operates too slowly and insufficient fuel gets to the fuel injectors or the fuel pump operates in the high speed position only.
His problem is the engine dies out after a few seconds or minutes of running.
Timeslip 08/12/06
