Old 08-01-2005, 06:11 PM
Ironhawk Ironhawk is offline
Question vavle interference engines
Any know if there is a list of cars that have vavle interference engines?
Please help I have someone telling me I should buy cars this way. Thanks for your help.
Old 08-01-2005, 07:01 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: vavle interference engines
Assume it does have an interference engine.
As far as I know almost all American made pushrod engines are, and most double overhead cam engines are.
some single over head cam engines are non interference, especially those with a narrow angle between the valves (where the valves are nearly parallel, like the Ford 2.3 liter 4 cyl.
So long as the engine is maintained properly, (ie; change the timing belt when recommended in the owners manual) it makes no difference whether its interference or not.
Old 08-01-2005, 08:34 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Yeah I cant see where that would factor in when buying a car, because that will narrow it down by like 90%.
Old 08-01-2005, 09:09 PM
Holyterror's Avatar
Holyterror Holyterror is offline
I guess if you want the ultimate idiot-proof car, then non-interference would be important. The older MR2 engines are the only ones I know of for sure. Checking your timing belt is not a big deal. And timing chains are not likely to snap, ever.
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05)
Old 08-02-2005, 12:38 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Ford Duratec V6's are non-interference, doesn't mean their idiot proof or easy to work on though.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 08-04-2005, 11:29 AM
Holyterror's Avatar
Surely not. I wasn't trying to imply that. I was just saying that the valve interference would only be a factor if you were trying to build an idiot-proof car.
Old 08-04-2005, 09:27 PM
Forunn Daberator
Yeah, we all know idiots break thier timing belts... because they are idiots.
Old 08-05-2005, 02:16 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: Re: vavle interference engines
I just finished rebuilding my GSX motor. Full rebuild, Heads, new valves, new pistons, bored, bottom end, all of it. Less than 3k miles on the motor I was on the interstate doing about 60 when I lost power. Cruise off to the side then get it towed home. Eventually discover the timing belt lost a bunch of teeth causing the motor to bend all 8 of the intake valves. Brand new timing belt too on the rebuild... piece of crap cheapness.
Old 08-05-2005, 04:10 PM
Forunn Daberator
Exactly.
Old 08-05-2005, 05:46 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Try gates.com.
Their application chart will show if the engine is interference or not.
You have to register 'tho, but no big deal.
Have fun.
Old 08-06-2005, 03:10 PM
Thanks Black Lotus and all the others that replyed. Your help is very useful.
