Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-01-2005, 06:26 PM
73gmcaz 73gmcaz is offline
Clunking on front left side 1987
Hi all!
I also just discoverd a clunking on the front left side of my 1987 Thunderbird V6 coupe.
Only does it when you ride over a bump so I was thinking strut but everything seems tight. Checked and repacked the wheel bearing and that was good.
Did not check the strut with the body jacked up so it could hang free with the control arm/wheel etc.
Any ideas would be greatly appreciated...the car is new to me.
Thanks
Brian
Old 08-01-2005, 09:36 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Clunking on front left side 1987
First thought is an end link.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-01-2005, 10:17 PM
Thanks!
Will change them and check it out.
Brian
Old 08-01-2005, 10:35 PM
coondawg6 coondawg6 is offline
agree with the link pin and also check upper strut mount/bearing plate should have no play at all
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-02-2005, 11:39 PM
SUERED SUERED is offline
....Another thought. While under there check the spring. We had a broken one on our '88. It was a hairline crack and not easily seen.
Old 08-04-2005, 09:34 PM
Jim Adams Jim Adams is offline
I just went threw this with my 89 supercoupe,,It turned out to be the upper ball joints ,,you can check real fast by just putting your hand behind the tire and with open palm smack down on the upper a frame at the ball joint and if it is bad it will clunk.
Old 08-09-2005, 09:41 PM
i dont think 87 had upper ball joints the strut and bearing plates replaced ball joints
Old 08-10-2005, 01:39 AM
I beleive you are correct in 1988 and 89 they went to new body style,,,On the style like yours check the upper strut bushing,,this is the bushing (bearing) that is at the top of the strut assy. and has 3 bolts in it that bolt to your tower
Old 01-31-2006, 10:37 AM
dlaughman@hotmail. dlaughman@hotmail. is offline
my 86 did that and a coil was rusted off down in the spring pocket so ya might wanna check their
Old 05-13-2006, 05:01 PM
CSSC1990 CSSC1990 is offline
The front end of my 1990 clunked when I would turn. I took it to a great repair shop. They looked it over and at first could not find anything wrong (visual inspection). They took it for a drive, came back put it on a rack, tightened the rack and pinion with a 6' cheater bar. No more clunking. In addition they didn't charge me one cent Goes to show not all problems are skin deep.
