Old 08-01-2005, 04:08 PM
PALLADIN72 PALLADIN72 is offline
Send a message via AIM to PALLADIN72
Stalling issue- Driving me crazy
OK, I have searched the forum, I am new as of today, and I am still at a loss. I have a '92 S10 Blazer 4 x 4, 4.3 vin z. It starts fine in the morning. It loses idle immediately. It will stall if my foot is not on the accelerator when I come to a stop. Moving no problem, even if I do not have my foot on the gas. After it stalls, it will not restart. When trying to restart, I do not see any gas from jets. To restart I must hit it with starter fluid (yes I know a bad thing). It will start immediately and keep running as long as I have foot barely on accelerator. After it starts, jets look like they work perfectly.
When it first started, we thought it was a fuel issue. I have replaced fuel filter and fuel pump to no avail. I* looked at the egr valve, but not sure what to do with it. It seemed like it was working OK. This has gone on for two weeks now. The last mechanic said it would cost about $500 to figure a problem like this out and that I can not do right now. Please help or put me on the right path. I am not much of a mechanic, but some of the guys at work are helpful, but they are stumped. Thanks in advance.
Old 08-01-2005, 04:43 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Stalling issue- Driving me crazy
I would check your IAC or TPS.
Old 08-01-2005, 05:43 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Do you have the VORTEC name plate on the top of your engine?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-01-2005, 06:02 PM
Re: Re: Stalling issue- Driving me crazy
No Vortec name plate, just checked
Old 08-01-2005, 11:26 PM
BlazerLT's Avatar
AF -Advisor
so you have the round air filter assembly?
Old 08-02-2005, 01:33 AM
Yes, that is right.
Old 08-02-2005, 01:54 AM
BlazerLT's Avatar
AF -Advisor
Check your battery voltage when the engine is running.
Check fuel pressure.
Old 08-02-2005, 11:18 AM
This morning rechecking everything again we noticed that a wire to the ECT was loose. We reconnected it and now the service engine soon light stays on. The code reader which had previously said everything was OK, now reads Code 15. Which is that sensor. I'm going to get a new one, I guess and see if that fixes the problem. Does that make any sense?
Old 08-02-2005, 11:26 AM
BlazerLT's Avatar
AF -Advisor
15 is the engine coolant temperature sensor circuit high (low temperature indicated)
Is the temperature low on the gauge?
Old 08-02-2005, 11:37 AM
Gauge reads normal. But it makes me think that since it starts fine in the morning when cool and as temp heats up it stalls that it is somehow related. I thought the sensor affected voltage to fuel sensor.
Old 08-02-2005, 12:27 PM
BlazerLT's Avatar
AF -Advisor
You should also clean the PCM grounds.
That code sets if there is a low temperature detected for 30 seconds or if there is a circuit fault.
Old 08-02-2005, 12:47 PM
Austin8214's Avatar
Re: Re: Re: Stalling issue- Driving me crazy
It does replace you temp sensor and you should be good to go.
Old 08-02-2005, 01:12 PM
What are PCM grounds?
Also, just replaced ECT sensor. Engine light no longer an issue. Codes read normal now. Engine still stalls and wont restart without starter fluid.
Old 08-02-2005, 05:46 PM
So now I've replaced the ECT and it still stalls. So I replaced the IAC and it still stalls. It starts cold, but when it warms up, it stalls and no gas from jets. Until it stall, it runs fine. No codes. Runs fine if I keep my foot barely on the accelorator. If not, it stalls. I am lost. Help????
Old 08-03-2005, 12:01 AM
BlazerLT's Avatar
AF -Advisor
Does the fuel pump hum when you try to restart it?
Ever replaced the fuel filter?
