Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-01-2005, 01:32 PM
bobinohio84's Avatar
bobinohio84 bobinohio84 is offline
Send a message via Yahoo to bobinohio84
93 Mercury wont start or crank
Okay so heres the deal I need some1 to answer me on this quick. My dad has a 1993 mercury grand marque and it has been idling a bit rough and comp check engine light came on briefly. Yesterday I was driving it and came to a turn and in the middle of the turn the blower kicked off and the anti-lock light came on. I figured I had just blown a fuse so I continued on my way. When I got to my destination the car stalled and I couldnt get it started back up. I just does nothing wont crank etc. I tested all the fuses and they seem fine. The neutral safety switch isnt working correctly the cruise isnt working apparently ( my dad said that ) and from what I can tell some fuses arent getting the power they should be with the key on. Headlights brake lights etc dont work hazards dont work radio does work wipers and windows and locks all work. I had a mechanic tell me that the only thing these have in common is the pcm computer so I bought one for $45 and that isnt it. Also in order to get it home I jumped it at the started and it started so please help me with this I need it running tommorow
Thanks, Bob
My car is my baby. Her name is Bridgette.
Old 08-01-2005, 01:34 PM
Talking
Sorry I meant I jumped it at the starter!
Old 08-01-2005, 11:06 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
are your termanals clean on your battery and the connections to the starter? and does hiting the starter with a hammer while some ones turns the key to crank it make it start?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 08-04-2005, 10:31 PM
Okay so after hours and hours of troubleshooting we figured out that somewhere there was a "non-functioning" fusible link. We didnt want to take it all apart so we just ran a new line from the fuse box and spliced it. Not the best way but it runs just fine now. We spent $45 on a comp we didnt need but other than that we wasted only time. We worked all day with the dash and ignition etc apart. I got onto alldata.com and got diagrams of the ignition switch even and checked the continuity to make sure it was good and it was. I've never run into this problem before and it was crazy so good luck and maybe this thread will save someone else time later. Thx.
-Bob-
Old 12-02-2005, 09:23 AM
Marco Sr. Marco Sr. is offline
Send a message via ICQ to Marco Sr.
Thumbs up Re: 93 Mercury wont start or crank
Unfortunately I'm comming in here a bit late but all of the fuse links are close to the battery and attach to the solenoid on the fenderwell, I have always found that the easiest way to test for a bad fuselink is just to tug on it litely if the insulation stretches then it is blown, when I have encountered blown fuselink it seems like they always burn a hole in the insulation on the bottem side where you cannot see it.
Marco Sr.
-Bob-
