Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-01-2005, 10:51 AM
ffjohnny ffjohnny is offline
Question Radio light out (intermitant) any ideas??
Hi Everyone,
I am sure someone hs had this happen before. The clock radio and station #'s are not working. The radio plays but the #'s are on and then go out. Any idea's
Thanks
John Cmarik
Old 08-03-2005, 11:04 PM
93hybridaccord 93hybridaccord is offline
something similar happend to my montana, the clock kept resetting and the time wouldn't hold.. took it to the dealership and this is what they found: " radio bad wire circuit, behind instrument panel chaffed".
this could be your case too, if you haven't checked that yet...
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 08-04-2005, 08:54 PM
Glen_T Glen_T is offline
John,
How comfortable are you working with electronics? I'd suggest removing the radio, assuming you can get to it - I've yet to figure out how to get to my 2003 Montana radio!
Once you get it out, I'd remove the covers and see if there are any wire "bundles" that go from the main circuit board to the display. One of them might be loose, so you might try carefully prying the connectors apart and re-seating them.
Another ugly possibility is that a circuit board might have a crack in it that is causing the intermittents.
GM (Delco) used to have an radio exchange program that was somewhat reasonable if the radio isn't fixable.
Hope this helps...Glen
Old 08-18-2005, 06:34 PM
dexterthedog dexterthedog is offline
There was a post on here awhile ago about this problem and it's what I came on here looking for now. It stated that there are "Light Bulbs" soldered inside the radio and are a replacable part but they need to be resoldered.
Why Light bulbs in this day and age is beyond me but if it is the case I'll post a full description after I chainsaw the dash out of this thing!
Old 11-22-2005, 07:12 PM
hazeldell hazeldell is offline
My problem with the light bulb was that it was burned out. It wasn't soldered in but twists out by turning the base of the bulb. Approx 7.50 Can.
