Old 08-01-2005, 11:10 AM
jwr870sx jwr870sx is offline
Shifting Problem
I have a 97 gt w/3800 engine. I was cruzin' down the highway last night at 70 mph not getting on it or anything. all of a sudden the car shifted out of O.D. into drive and ses light came on. I let off of the accelerator and the r's dropped to idle speed. Stopped car and started up again, car did not shift down, stayed in 3rd. Manually shifted ok but still didn't go into O.D. Stopped car again shut it off and every thing worked normal???? Can anyone tell me what is up?
Old 08-01-2005, 12:05 PM
jessep28's Avatar
jessep28 jessep28 is offline
Re: Shifting Problem
Since the SES light came on, you can take the car to Autozone and they will usually scan it for you. Get the codes, resist any parts sales pitches and bring them here and the guru's here will tell you the possible causes.
I would also consider taking it to a transmission shop and they will run a diagnostic for you.
Old 08-01-2005, 10:39 PM
Thanx, I will set up a diagnostic tomorrow and get back with the codes
Old 08-04-2005, 04:57 PM
The code is 502 speed sensor low voltage. The guy who pulled the codes said to clean the plug in to start with than go from there.
Old 08-04-2005, 07:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Tranny DTC error code P0502 is vehicle speed sensor (VSS) circuit (low input). The sensor is a permanent magnet generator mounted to the transaxle case extension. It feeds the PCM to determine shift timing, TCC (torque convertor) apply and release, and gear ratio calculations. The PCM will receive and process the AC voltage and convert it to digital.
You can start by cleaning the electrical connector plug. If that doesn't work you can check the resistance and voltages with a multimeter.
VSS resistance = 981 - 1864 ohms
VSS voltage = .5 volts AC at 100 rpm to more than 100 volts AC at 6000 rpm
BTW - To check output voltages the engine must be running and transaxle/wheels must be turning. Not an easy job in this respect.
Good luck!
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-04-2005, 10:05 PM
regalfriend regalfriend is offline
i had similar problem....low voltage...i lost 4th gear and lockup...the ECU was checked and found no malfunctions. Turns out turbine speed sensor was replaced and voltage came up...I dont know if TSS will effect voltage but know that voltage did come up after repair
