Old 08-01-2005, 08:39 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
disabling pcv on street car?
RRE says you can disable the pcv on "cars that never see the street." is this because of emissions or because it will run differently???? i already disabled the pcv on my car and didnt even think of why they said it should only be done on a track car. i assumed it was because emissions. so my question is: is it cool to disable it on a street car in regards to performance/drivability rather than emissions.
Old 08-01-2005, 10:56 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: disabling pcv on street car?
PCV stands for Positive Crankcase Ventilation. NOW tell me, do you think it should be on there? It's there for a reason.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-01-2005, 01:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
It only affects emissions, not performance. Positive crankcase pressure is vented by the side port on the valve cover, which goes to the intake on a stock car to keep it closed loop, again for emissions. I removed the PCV valve and installed a spare brake booster manifold fitting in its place (a 1/8 BSP to 3/8th hose barb fitting from mcmaster carr would be the same thing) venting the valve cover through 2 3/8th hoses. I still had trouble blowing out dipsticks at over 60 lbs/min airflow on one of my new motors.
If I had retained the PCV valve it would have been even worse, since hte PCV closes under boost So if venting the crankcase is a concern, the PCV is making things worse. NOW tell me if you still think its necessary.
You have to first understand how these systems work and why they are put in place before making decisions or giving advice about them.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-01-2005, 03:57 PM
-Josh-'s Avatar
Re: Re: disabling pcv on street car?
I understand how PCV works, i'll keep mine on thank you, it aint hurting performance enough for me to remove it.
AF User Guidelines
Old 08-01-2005, 05:00 PM
AF - Advisor
Re: Re: Re: disabling pcv on street car?
And that will be the case for 99% of DSMers. But removing will not affect performance, just emissions. Which was what RRE was getting at on thier page.
Kevin Jewer
Old 08-01-2005, 09:57 PM
words of wisdom
