Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-01-2005, 08:22 AM
73gmcaz 73gmcaz is offline
87 Shift Indicator help
Hello all!
I have a 1987 T Bird V6 Coupe w Auto Trans and the shift indicator is all out of whack. Shows P when it is really in Drive etc...how can I get to the indicator to check it out?
Thanks!
Brian
Old 08-01-2005, 09:51 PM
coondawg6 coondawg6 is offline
im not recalling where the indicator is on the 87 . is it a floor shift or column shift and is the indicator instrument mounted or console mounted?
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-02-2005, 08:06 AM
Sorry for the lack of detail.
It is column shift and the indicator is in the instrument panel, just above the steering column.
Thanks,
Brian
Old 08-02-2005, 11:25 PM
take the lower cover off under the steering column and the bolts that hold the column up to the dash lower the column and there should be a string hooked to the shift collar you can adjust the indicator there or adjust the linkage at trans BTW at the trans is easier/look for bushings on the shift linkage that are probably worn out
