Fuel Pump resistor
Please tell me just where EXACTLY is the resistor located near the fender well.of a 98 gp gtp.
Injection is nice But I'd rather be B L O W N. |
Re: Fuel Pump resistor
This may help. Try this link:
http://rmcgp.clubgp.com/fpresistor.html ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
Fuel Pump Resistor
Thank you.I just wish i would have asked earlier as i ordered a new fuel pump yesterday.
Fuel Pump Resistor
Ok,I tried the jumper wire trick and the car still died.Does that mean the pump is bad?
Re: Fuel Pump Resistor
To confirm a defective fuel pump the best thing to do is run a fuel pressure check at the schrader valve located on the fuel pressure regulator. Its located on the fuel injector rail for the even bank of cylinders (front engine). It should read 45 - 55 psi. If it doesn't then the fuel pump or clogged fuel filter is likely. Plus, there are other things that can cause your problem even though no SES may be on. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
