Old 07-31-2005, 10:53 PM
Jaime82 Jaime82 is offline
Lightbulb Plymouth Voyager Blower Motor Relay Problem
I just bought a 97 Plymouth Voyager and I'm having a problem with the blower motor relay. On the right side it only has half the power it should have. Also the blower motor won't turn on by moving the switch inside the van, you have tap the relay and then the blower motor comes on. Then when the blower motor is on it will shut off when you put the van into reverse. When we jump the relay over to work from another relay, everything works great. Anyone have any suggestions on what could be the problem here?
Thanks
Jaime
Old 08-01-2005, 01:15 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Plymouth Voyager Blower Motor Relay Problem
If I understand you correctly, you switched relays and it worked? If that's the case, then it sounds like you have one of two things, a bad connection between the relay and the terminals or you have a bad blower motor relay.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-01-2005, 08:49 AM
B33p3r B33p3r is offline
Get a new relay
Old 08-01-2005, 01:04 PM
Re: Re: Plymouth Voyager Blower Motor Relay Problem
We ran a jumper wire over to another relay to get power from it and it worked fine. We tested the terminals of the relay and the one on the right only had half the power it should of had. What sends power to the terminals of the relay?
Thanks
Jaime
