Old 07-31-2005, 04:06 PM
RG501 RG501 is offline
Send a message via AIM to RG501
Kicker 12” Comp Subwoofer
http://www.circuitcity.com/rpsm/oid/...cation.do#tabs
I work with a guy who has 2 of these in his blazer and he showed them to me today and i thought they sounded really nice. he had 2 of them in a sealed box and i was thinking of getting one to put in my firebird. it says it is a 300 peak power sub. so im guessing the sub is about 150RMS watts? i need a amp to power it. i think a Profile AP400 would be good enough to power it. it puts out 200rms watts bridged. tell me if you think this should be good.
1996 v6 Pontiac Firebird
Old 07-31-2005, 04:23 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
should be plenty of power for it
Old 07-31-2005, 04:26 PM
alphalanos alphalanos is offline
That should sound pretty nice. My friend had a Comp VR in his Camaro and it sounded really good so your setup should be pretty much the same.
96 EJ6. Future home of boosted B18C1.
Old 07-31-2005, 06:38 PM
Re: Kicker 12” Comp Subwoofer
do you think it'd be too much power and when i crank it, it'd blow the sub?
Old 07-31-2005, 06:42 PM
No the Kickers are pretty strong subs. It should take it pretty well. Plus your amp wont actually be delivering 200 full watts to the sub, due to your electrical system not actually being 14.4 volts, which is what the amp is tested at. So it should be just about perfect.
Old 07-31-2005, 06:44 PM
another thing: will this setup sound good when i listen to rap as well as rock/metal?
Old 07-31-2005, 08:09 PM
Well its not going to give you huge boominess, but should respond well in most frequencies. Try a normal sealed box first, and if you dont like it then try a larger ported box. If you really think that this may not give you enough bass, try a more powerful sub and amp. But it should sound pretty good.
Old 07-31-2005, 08:19 PM
ok, will it give me alot of bass when i listen to rap?
Old 07-31-2005, 08:45 PM
Should be ok...it wont be like heart pounding or anything. But it should be pretty deep and hit well. You will probably want to upgrade in the fuuture so you might want to consider something better the first time around. It depends how much you want to spend and how much bass you really want. If you want ALOT of bass try a good sub like JL W7(13) or similar, or mabye even a 15.
Old 07-31-2005, 08:51 PM
maybe i should get 2 of these subs then. what kind of amp would i need if i got another one of these subs?
Old 07-31-2005, 09:02 PM
well just any decent amp that puts out around 150rms x 2 @4 ohms. something like this but doesnt have to be that expensive
Old 07-31-2005, 09:09 PM
so each channel has to put out 150rms watts at 4 ohm?
http://www.millionbuy.com/prfcl600.html
that amp should work then.
Old 07-31-2005, 09:24 PM
yeah that will work
Old 07-31-2005, 09:32 PM
the guy that showed me these subs had a sony 600 watt amp. and thats what that Profile amp is (600watts). so im guessing it should sound alot like his.
Old 07-31-2005, 10:03 PM
what would i lose if i got 2 10" Kicker comp subs rather than 2 12" subs?
