| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
Help Needed Fast!!!!
95 3.1 Cutlass
Everything was fine, i was driving along and heard a loud rattle noise coming from the engine, i get out and look, and it looks like my tensioner pulley was wiggling a little. i cut the car off to check it out and it felt tight, tried to start it back up and it will not start..... When you turn the key to crank it,... the belt wants to move but,,will not move. Is this caused by the tensioner pulley? The car is sitting in the BP parking lot. I bought just a pulley and put on and still no luck.... Could the entire assembly be bad? Need help FAST!!! RAY |
Re: Help Needed Fast!!!!
Your loose belt must have not been turning the alternator enough to keep the battery charged and is now run down. Get some jumper cables and get a boost from another car.
Oh lord that sucks. Good luck getting it fixed!
Aka 93 Cutty Working on my next project: A 1986 Honda CRX. Little beater with lots of engine ![]() Car Audio Freak http://www.sounddomain.com/ride/613185 |
Re: Re: Help Needed Fast!!!!
I guess when i put the flywheel in, it probably was already cracked and wasn't able to see it. I'll pull the motor and replace it... it should only take about 4 hrs and i should be rolling again but, it does suck. |
Wow if you can do it that quick you must know what you're doing. I'd be sol if that happened to me.
EDIT: good luck!
Re: Re: Re: Help Needed Fast!!!!
When i bougtt the car i had to put the motor in it.I pulled the motor and tranny at the same time. When i did the flywheel , i only pulled the motor and then only enough for it to clear the vehicle..... Chiltons and these forums are good search engines for reference, labeling wires and putting bolts in ziplock bags is a good thing also... |
