Old 04-29-2002, 09:00 PM
Corwin Corwin is offline
Help on engine swap
Hey all,
I need help figuring out what to do with a swap. Im swaping out the engine on my 89 CRX Si. I have a long list of engines that i can put into the car but i dont know the pros/cons of each.
Friend of mine can get me a B18C5 (type-r i beleive) but i hear that is a bastard to install
what engine whould you sugest and what all do i need besides the engine?? <tranie, drive train, suspention, ecu???>
thanks for any help
Old 04-29-2002, 09:03 PM
Poweredbyhonda's Avatar
Poweredbyhonda Poweredbyhonda is offline
Send a message via AIM to Poweredbyhonda
All B-Series engines need New mounts from HAsport.com or placracing.com, also Hondamotorsonline.com sells complete swaps! Everything u need!
I am going ZC/Turbo, u can use all of ur stock stuff except u will mostlikely need a new ECU!
Good luck!
Kyle Cox
project eg hatch in progress
http://www.nsmotosports.cjb.com
:badass:
Old 04-29-2002, 09:52 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Don't forget the D16z6 or D16y8. They're cheap, have 125hp, and VTEC. They also bolt right up, and you can even use the tranny in your car now. Also, it's a USDM engine so parts are a lot easier to get, and the aftermarket support is fairly large. The drawbacks are that if your going to use the p28 ECU, which is highly recommended, there is a lot of wiring which is a PITA, and the motors are only SOHC.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 04-29-2002, 11:06 PM
Chhuong Chhuong is offline
Send a message via AIM to Chhuong
If you can afford it i'd say go with the b18c5, otherwise go with a b18c1, you will be happier believe me. If i had to do it over i would've gotten one of those instead of the b16a. Although the b16a is doing very well for me.
Old 04-29-2002, 11:24 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well it also depends if he wants to go BOOST ( i hate turbo ) or ALL - MOTOR ( i worship anyone whos down with all motor ) so it just really depends. IF you're goin all motor then i'd get the b8c5 , but b16 is my favorite to tell you the truth. Its affordable and it has so much freakin potential man! aahh fuck it ...do whatever you like!:finger: d
Old 04-30-2002, 12:20 AM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
B16 swap is easy and relatively cheap....
www.phhatwhippinCRX.20m.com for swap info
Also, same page for the ZC swap....
For boost, either B18a/b or B20z/b..... both are better choices and less expensive than either the B18c1 or B18c5....
B16a is still a very kickass motor...... but boosted B20z/b is where it's at....
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 04-30-2002, 12:34 PM
Dam, thanks for all the info guys. that was fast work for one night.
I was thinking of going with the B18C5 cause a freind of mine can hook me up with the engine and trany for about $950 but i will still need to hunt down axles, mounts, ecu and all that.
anyone know if the over all weight is an issue though?? would somthing like this effect the handeling of the car?
Old 04-30-2002, 12:52 PM
mellowboy's Avatar
DAMN 950!!! Yeh i'd definatley go for it especially that price man! Oh about the weight, its not gonna affect it that much. Its safer u have upgraded suspension though?
Old 04-30-2002, 01:02 PM
no i dont have any upgrades on the suspeson yet. that was actualy one of the first things on the list to do, but then the timing belt blew........so yea engine swap first
and holy crap i just went to hondamostersonline and saw the same engine for close to 4 grand
HEEEEEEEEEEEEEEEELLLLLZZZZZZZZZZZ NOOOOOOOOOOOO!!!
Old 04-30-2002, 09:38 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
whos your friend? can he get more? i got 950 right here send it to me
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-30-2002, 10:25 PM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
are you sure on that price? i would get it in writing...and maybe check the engine out and see some papers before i bought it..you're talking about a $5000 engine for under a grand...seems kinda shady to me...if people could find b18c5s for 950 everyone would have one...even stolen..someone would have to be a jackass to sell it for 950!
i hardly would ever recomend a b18c5 swap. not unless you have a ton of money.
go with the b18c1..gsr engine. it will save you so much. then you can use the money to fix that up.
i went with the b16a. it came with the 160hp and zero torque. but hey, it cost $1100 shipped. then i used that extra $4000 that i didnt use to buy the b18c5, and i gave my b16a another 240hp 160lbs torque. just all motor my b16 out ranks a type r by almost 70hp 50lbs torque. and after all the work..i think i have enough money left over to buy another b16a.
so like i said. the only times i would recomend a b18c5 would be in a show car (due to rareity of the swap...as expensive as it is, i still think its a cool thing to see), or if you had a ton of money to spend. if i had say 6-7grand i would have gone with the type r too...but i didnt.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 05-01-2002, 07:22 AM
ricodemus ricodemus is offline
Originally posted by threethirteen
... then i used that extra $4000 that i didnt use to buy the b18c5, and i gave my b16a another 240hp 160lbs torque. just all motor my b16 out ranks a type r by almost 70hp 50lbs torque. and after all the work..i think i have enough money left over to buy another b16a.
damn dude, what is your setup? thats a bad ass car...
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
Old 05-01-2002, 08:55 AM
mellowboy's Avatar
shit i'd like to know also since i'm goin all motor.
Old 05-01-2002, 09:23 AM
heh...a lot of work...and good prices. a lot of help from friends. basically i dont know much about engines..i know heads, and bolt-ons..i can custom a hella turbo kit..and i found that im good at finding where the engine bolts are..
but i ended up with some JE pistons, esp rods, headwork is mostly skunk2 and spoon sports...some hks cam gears. nice p&p, block was resleeved...and some other crap (i dont know i didnt touch the block, im only good with giving good heads...:licker: j/k)
we took a b16a from a 2000 civic si...stripped it..then put all new crap in it. except the ctr crankshaft was used (like 3500miles. or something)...
after that i slapped a turbo on it..i dont really use it high though...its set at 6-7psi..
it seems a lot more attainable that it is..people underestimate the b16s...i love them. i tried getting a b16b...but no go. but i guess there wouldnt have been much difference..just the serial number.
Old 05-01-2002, 09:46 AM
mellowboy's Avatar
Shit i'd thought u were all motor? Anyways nice set up. I bet u guys saved a whole lot of money since you and your friends did the workand don't have to pay for labor
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Need help Engine swap 91 HF Supra24valve '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-10-2005 08:27 PM
NEED SOME Vtec HONDA HELP! ENGINE SWAP! 93_R/T_TT_Stealth '88 - '91 Civic | CRX | Wagon | Shuttlee 14 08-18-2004 12:33 PM
