Old 07-31-2005, 02:41 PM
BAGrandAm BAGrandAm is offline
Exclamation A/C has correct psi but is not cold
My 98 grand am 2.4L is not producing cold air when on max.
I purchased a can of refrig. to charge system but gauge shows the pressure to be at 35psi. I checked the clutch on compressor to ensure it is engaging and it is. Air flow seems fine but just not cold. Is there a temperature sensor that could be bad?
thanks for any input.
Old 08-01-2005, 03:37 AM
Hoags's Avatar
Hoags Hoags is offline
Re: A/C has correct psi but is not cold
Is the A/C blowing cold on the regular A/C setting?
Old 08-01-2005, 03:47 AM
Hoags's Avatar
Depending on where you live and how hot the temp's have been it may take a while for the car to blow cold on the max setting since the max setting recirculates the air from inside the car, if it is real hot outside and you are driving with the window down waiting for it to blow cold air it will take even longer, my wife was doing that and would complain that ut was not blowing cold. I had her put it on the regular setting until it cooled down a little then close the window and run it on max...she had to turn down the fan speed because it was getting too cold.
I hop this helps in your situation.
I almost forgot...Welcome to the forum. If my suggestion is not the problem let us know the people here on the forum are very knowledgable and we should be able to help resolve your problem.
Old 08-01-2005, 06:25 AM
Sorry fogot to mention my wife was the one who noticed the problem which I suspected the same thing you did but after my 40min commute home one evening I realized she was right (like always). None of the settings seem to cool the car.
thank you for your help
Old 08-07-2005, 06:46 PM
Ps3sucks Ps3sucks is offline
cars dont screw up cars women screw up cars.
Old 08-07-2005, 06:59 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Re: A/C has correct psi but is not cold
That really contributed to the thread.
Old 08-07-2005, 07:57 PM
well I felt it related to the post before me.
Old 08-07-2005, 08:07 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It sounds like the evaporator core has an external blockage. Be prepared to spend some time on this one. You need to take the lower half of the dash apart on the passenger side to expose the core, make sure there is nothing caked on it. It looks alot like your heater core, which also bears a strong resemblance to a radiator. If that's not the problem, check all the duct work while you are disassembling everything, make sure everything works the way its supposed to. Expose the core, start the car and turn on the AC. The core should get really cold, if not the expansion valve might be stuck or the filter is clogged, they are both in the same place and usually require dealer or ac specialist service.
Old 08-07-2005, 09:35 PM
thank you, that gives me somewhere to start. Is the expansion valve located at the evap? I was told to check the low pressure sensor also, but if there was something wrong with the sensor would the compressor even engage?
thanks for the help.
Old 08-08-2005, 05:04 PM
If the low pressure sensor is not giving a reading, the compressor should not start. When its cooler out do you get cold air from the ac?
Old 08-09-2005, 06:12 PM
It seems cooler with outside air temp cooler, but its not cold air.
Old 08-09-2005, 07:14 PM
CDJr CDJr is offline
Did you also check the high pressure reading? And the 35 psi was at idle? You should check it at about 1500-2000 rpms and see what the pressure is or if the compressor is cycling off from the low-pressure switch.
Old 08-10-2005, 09:32 PM
the 35psi was at idle with fan on max. I have not checked the high pressure side. What is the normal range for the high pressure side of system?
thanks for everybodys input!
this is definetly a learning process for me.
Old 08-11-2005, 10:12 AM
Always check pressure with engine around 1500-2000 rpms (which is the normal operating level). This will give you a more realistic-operating reading. If its 35 at idle, using 134a, Id guess its just a lil bit low, probably not much. Try that and see if the compressor is cutting off as the pressure drops. Theres also probably a sight-glass indicator on the high-pressure side that you can check.
Old 08-17-2005, 05:19 PM
Just checked psi at higher rpm. It was still around 35psi at 2000rpm. I have started taking apart dash at evaporator location. cycled through defrost, ac and max settings to make sure all valves/vents are opening which they were.
I will keep everybody up to date with my discovery
thanks
