Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 07-31-2005, 10:24 AM
novo48 novo48 is offline
Antifreeze leak
my gf has a 97 sebring jxi convertible. it has 115k miles and just had the water pump replaced. and every once in a while the car will overheat and allllll of the antifreeze will leak out. and i mean alllll of it. then if she puts in new antifreeze it just happens again a little further down the road. she really needs her car asap. could someone please help me out with what to do? or what the problem could be?
Old 07-31-2005, 10:33 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Antifreeze leak
it's a possibility that the last person who did the water pump didn't put a simple $2 o-ring that connects the water pump to the water pipe and that's why she has a leak. Another possibility is a busted water pump gasket. Also, check the radiator for cracks in the seams; if you can have a pressure check done on the system to isolate the leak exactly.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-01-2005, 10:03 AM
how much do you think it would cost to have a mechanic look at it. im not really too smart with cars.
Old 08-01-2005, 09:54 PM
Re: Antifreeze leak
most independent shops don't charge anything, some go as high as $40 to look at, either way, it's still cheap. Like I said, they can perform a pressure test on your car and see where the problem lies specifically.
Old 08-05-2005, 10:37 AM
ok...so the guy says that it needs a radiator. and becuase it was not starting up a lot of the time. its gonna need an alternator and a battery. he's gonna charge us 800. is that good?
Old 08-29-2005, 10:20 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: Antifreeze leak
that sounds like a shady mechanic trying to sell you an unneeded alternator and battery to me
were you having any problems with the battery or alternator?
Old 08-31-2005, 08:21 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Antifreeze leak
I agree, but if you do need a new battery and alternator, the alternator is a real PITA to get out. I did one on my wife's 2000 sebring and it was not fun. Did he say why you need a new radiator? Is it clogged, leaking, or what?
Old 09-18-2005, 12:05 PM
toyo_love toyo_love is offline
I am having the exact same issue and mine is due to the cooling fan intermittently not turning on. Don't replace your radiator unless there is a leak! Turn on your AC and see if the engine fan is blowing. If it doesn't then the cooling fan is your issue. Let us know how it goes.
