Old 07-31-2005, 12:15 AM
steven_mckenz steven_mckenz is offline
Revell Viper GTS Problems
I just got this kit and started working on it (since I broke my other kit, gotta find some putty somewhere). I have painted the main body, and have began dry-fitting the other pieces, like the bumpers and hoods and such. However, I came across a problem. This whole kit had AWEFUL extra plastic around the edges of the pieces, that I've had to slice off and smooth out and everything. I didn't have a problem for awhile, until I got to the back bumper. This thing looks like CRAP. The top of the bumper I can see has a decent amount of extra plastic on the top of it. I will cut it out, but this pieces does not seem to have the right angles on its sides to fit on the main body part.
Do any of you guys know which piece I'm talking about, and have done this kit before? Is it normal for this piece to not fit well at all? Does it need some work on it to fit, or do I just have a bad piece? Thanks for your help!
Old 07-31-2005, 12:36 AM
HotRodDreamer HotRodDreamer is offline
Re: Revell Viper GTS Problems
if after you're done taking the "flash" off the edges and you dry fit it, and it's way off as far as fit and doesn't look like the car should i'd recommend ordering another piece from Revell. While you're taking the flash off though, be sure not to take off any tabs that are used for mounting it to the body. I remember this kit as my second one ever made and it was a good kit. As i recall, the back bumper; back part of spoiler, and the taillight housings are all on one piece
IN SLOW PROGRESS - - Revell '69 Yenko Camaro
- -Black on black with white stripes and BMF- -
Old 07-31-2005, 12:52 AM
Jaymes's Avatar
Jaymes Jaymes is offline
I never built this kit, but I think I encountered a similar problem with my Revell Camaro SS. I somewhat fixed it by sanding it on a flat surface, or wrapping sand paper around a ruler and sanding so that the surface is even.
Old 07-31-2005, 12:53 AM
Here are some of the pictures of it to further explain what I was talking about.
Here you can see the curvature of the back of the GTS for reference...
Here's the bumper. I cleaned up the extra plastic fairly well, so that doesn't interfere with putting the pieces together...
Here's the bumper's curvature...
Here's how the two pieces fit poorly together...
Do those pictures help out a little bit to explain what I'm trying to say? (I suck with models, lol...)
Old 07-31-2005, 01:03 AM
blubaja's Avatar
blubaja blubaja is offline
Edit: welcome man
Old 07-31-2005, 01:15 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
It looks like those two tabs are just injector marks or something: Is there any hole for them to fit into? If not, cut them off and try it then.
That happened to me a little bit but it was nowhere near that bad, when i built it i was pretty happy with the entire kit, i dont remember there bein tabs there either, mebbe the mold just started to suck and now all the viper kits are crap. You could try bending the spoiler part of the rear or somethin, heat it up a little and coax it to match up better, hard call though, it used to be different
Old 07-31-2005, 01:20 AM
I fixed it. It turned out that the bumper is SUPPOSED to be sunken into the body a little bit. I guess that's how the vipers are made, the sides sink in a tad in the bumper. I pushed the bumper all the way in, sinking the sides a hair and putting those two tabs into their holes (that they were supposed to go in, sorry I forgot to mention that) and it looks a little better. I still don't like how the sides of the bumper are sunken inside the body, but that's the way it looks like it's supposed to be according to some reference pics.
Thanks for the help and thanks a ton blubaja!
Old 07-31-2005, 11:35 AM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
Yeah, I had a good bit of problems with the rear bumper on this kit. The GTS actually has scoops tucked into the corners of the bumpers, which the kit fails to capture. When I built this kit, I puttied the back smooth and omitted these scoops.
*Lady Modeler*
Hers:
2000 Mustang GT - Bright Atlantic Blue
1999 Honda Civic - Milano Red
His:
1999 Camaro SS - Hugger Orange
1969 Camaro w/ LT1/T56 Swap - Hugger Orange
Old 07-31-2005, 11:12 PM
tmathew1us's Avatar
tmathew1us tmathew1us is offline
Yup, I think that is how the back end is supposed to look
