Old 07-30-2005, 11:53 PM
diddy0071 diddy0071 is offline
Send a message via MSN to diddy0071
1997 Blazer Surging Forward
When I'm at a stop, I notice my blazer idle high, and actually make the vehicle surge forward, unless I press on to the brakes tight. I don't know what the problem is. I got the vehicle checked for vaccum leaks, and got that fixed. I got my coolant flushed 2 days ago, and yesterday I got my A/C serviced. I also replaced a 02 sensor a few weeks ago (the one before the CAT CONVERTER) and that didn't seem to help. I'm all out of Ideas, and I don't want to take it to the dealer, or anywhere else for that matter. The Coolant cost me $80.00 plus $140.00 for the A/C. That's $220.00 in 2 days. I'm really low on cash right now, so I would like to fix this myself.
"I'm a jerk, not an asshole!!"
Old 07-31-2005, 12:55 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1997 Blazer Surging Forward
Any check engine lights?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-31-2005, 12:57 AM
The Only one I got, was 3 weeks ago, about the 02 sensor bank 2. SO I replaced the sensor. No other SES lights ever since.
Old 07-31-2005, 01:02 AM
BlazerLT's Avatar
AF -Advisor
I still think you have a vacuum leak.
Spray all the vacuum lines with carb cleaner especially where they connect to their fittings.
If you note an increase in idle when spraying a particular area, you may have found your leak.
Remember, use CARB cleaner, not throttle body cleaner.
Old 07-31-2005, 01:04 AM
Well, A few weeks ago, I asked a question about the air conditioner switching from the vents to the defroster by itself, and I was suggested to check for vaccum leaks. SO I actually took it in to Midas. They checked for any/all vacuum leaks. So There shouldn't be any.
Old 07-31-2005, 11:05 PM
BlazerLT's Avatar
AF -Advisor
A blind assumption is the mother of all automotive screwups.
Since when is Midas a place for engine problems.
If you don't want to take my advice, that is fine, but sitting behind your computer and not trying what I am telling you will get you no where.
Old 07-31-2005, 11:08 PM
Yeah, I know Midas is not a mechanic, but I just wanted to get the A/C checked out. ANYWAYS, I checked it this morning, and still didn't find any leaks. I used a CARB cleaner, and couldn't find anything. I give up though, I might as well take it to a mechanic. Time to whip out the old VISA.
Old 08-01-2005, 01:34 AM
BlazerLT's Avatar
AF -Advisor
Check the vacuum hose going to the vacuum diaphram for the 4x4 actuator.
Also check the hose going to the vacuum ball.
