Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 07-30-2005, 11:29 PM
pdreher pdreher is offline
Send a message via Yahoo to pdreher
96 Tracker Signal Switch, Need Help!!!
OK so here is my problem. The turn signals dont work on the 96 tracker 4 wheel. But the 4 ways do and everything else on the turn signal switch. When you put the turn signals on it blows the fuse. The flasher is new and i think the turn signal switch is bad, if so where should i get one, and how do i take the steering wheel off, with the air bag? Please help me.
Old 07-31-2005, 06:05 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
you can get a new switch at your local parts store like autozone or if you want to save money check your local salvage yards , i would take it to a shop to have it replace , you have to know what your doing when taking an airbag out
1986 Kawasaki ninja ZX1000R
1989 Honda Civic HB
Old 08-01-2005, 05:51 PM
Re: 96 Tracker Signal Switch, Need Help!!!
so you think the problem is the turn signal switch???
Old 08-02-2005, 03:30 AM
it sounds like you can short in the system somewhere , i would take all the bulbs out then turn the turn signal on and see what happens , then just put back one bulb at a time will you keep checking it , i think you have a short in the turn signal system since it blows the fuse when you use them
1989 Honda Civic HB
Old 08-03-2005, 07:38 PM
thanks for the help i will try that.
