Old 07-30-2005, 09:40 PM
molf molf is offline
A/C problem
I have a 89 Honda Accord and the AC Compressor does not turn on. At first I thought it must need a recharged but then I realized the light on the "AC On" button quit working the same time the AC quit working. I checked the fuses under the hood and the fuse box under the dash and the are all fine so next I confirmed the AC switch was working and that was as well. I read in another post about a 7.5 Amp fuse that conrols he compressor clutch but nowhere in the post does it say where to find this fuse. Do you have any other suggestions????
Old 07-31-2005, 12:54 AM
deaz's Avatar
deaz deaz is offline
Send a message via AIM to deaz
Re: A/C problem
Well, it could be one of 3 places... The passenger side fuse box, the drivers side fuse box or the underhood fusebox... Have you checked all of those places? Also, in your manual should be a list of all fuses as well as where they are located. If the fuse isn't blown, I'd suggest checking the ac relay.
Old 08-01-2005, 12:01 PM
Re: A/C problem
I checked in the manaul and I do not see a A/C relay anywhere. Where should I look for this relay???
