Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 07-30-2005, 07:04 PM
bobbyg123 bobbyg123 is offline
1996 Chrysler Concorde Shaking
Hey all,
My Concorde shakes at about 20 to 30 mph and then stops at higher speeds. I have a 3.5L motor with avbout 160K miles on it. It might be shaking when the transmission is shifting but I really can't tell. Also there is a popping sound coming from the front end when breaking or when first accelerating. Any Ideas? Thanks in advance!
Old 07-31-2005, 10:21 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1996 Chrysler Concorde Shaking
you may have worn tires or an out-of-round rim. The popping sound could be a worn control arm bushing or sway bar bushing.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-17-2005, 09:45 AM
felix888 felix888 is offline
Originally Posted by bobbyg123
Hey all,
I had the exact same problem with my 99 concorde, had the wheels balanced three times and it kept reoccuring. Turns out it was a busted tie rod. My father in law was able to replace in about two hours and the replacement part was $60.00. Chrysler was going to charge $350.00! to fix it. It was about moderate in difficulty.
Old 09-06-2005, 08:18 PM
Bizzy102 Bizzy102 is offline
Tie Rods On Lhs, Concords And Intrepeids Are Juck, They All Go With Some Of The Smae Symptoms.
Old 09-19-2005, 10:13 PM
bayoucajun101 bayoucajun101 is offline
Re: Re: 1996 Chrysler Concorde Shaking
If you hadn't got it figured out yet, I had exactly the same problems with my 96. The knock during take off and stop is a broken transmission mount (bad rubber); easily replaced. The shaking during acceleration (through the steering wheel); bad transmission fluid & filter. Replace both. Remember Dodge & chryslers only tale ATF +3 or +4. If somone added the wrong fluid in the past there's your problem.
Old 12-28-2005, 09:45 AM
Ryuichi Ryuichi is offline
Re: Re: Re: 1996 Chrysler Concorde Shaking
Could too much transmission fluid cause the same problem? I just got my mom's car for Christmas, and it shakes while accellerating. I don't know too much about cars yet, so I'm not sure where the drain plug for the transmission fluid is.
Also, the cruise control randomly turns itself off. The computer has recently been rebuilt, and that fixed many problems with it.
Old 11-20-2008, 07:50 AM
rchene rchene is offline
Did you find the solution to the shaking problem?
Old 02-01-2009, 09:40 PM
Symptom: Front shakes very badly during acceleration, especially bad at 45 - 70 mph. it was worse with light acceleration, not too bad bad if you floor it through these speeds.
I finally fixed the problem! I had taken it to the dealer for diagnosis and the wrote it up for everything under the sun EXCEPT the CV axle. I questioned that since I thought the RH inner seemed too loose. They assured me that was normal for these cars. I've been replacing parts gradually for the last 1 1/2 years since and been unable to find the solution. Finally compared my CV to another Concorde that didn't have the shakes. CV was much tighter. I replaced the CV axle today ($60 @ AZ) and the shake is gone.
The needle bearings had come out of one of the 3 slider rings in the inner joint allowing the axle to come off-center.
Old 04-22-2009, 09:45 PM
JMulhollan JMulhollan is offline
I have a 96 concorde as well and it shakes too, but it does not shake during acceleration only when it is idling. I am not car savvy at all so I'm not sure what it could be. I have a friend who knows a lot about cars and mentioned to me what it could be but I cannot remember what it could be.
Also, my car always seems to drift to either the left or the right when the steering real is straight. I've had the car aligned 3 times in the past year and every time it gets aligned and the tires rotated it seems to drift in the opposite direction. I had a tie rod replaced not too long ago too.
Any help would be greatly appreciated thanks
Old 04-24-2009, 06:18 PM
AWP9521 AWP9521 is offline
The engine shaking at idle problem (especially on the 3.5 engine) is caused by a leaky intake manifold gasket. Should you attempt to fix it yourself, get a haynes or chilton's manual for the car and read through the procedure a few times before doing the task, should take you a few hours to do the fix yourself.
I seem to have the same problems with the car drifting, I'm thinking that the tire diameters on the car are so far off that it is causing the drift, and yes rotating them does make the drift change direction, also I have found running one tire a little soft and the other at a higher pressure tends to cure the problem somewhat (still drifts but not near as bad) which leads me to believe i have a tire problem. I'm getting a new set of tires next week and feel that it will cure the problem, will post if it does.
Regarding the Tie Rod Ends, well the outer ends indeed will wear out in time as they are not greasable, replacement units are so their life can be extended. The inners admittedly are not that great, they are merely a rubber bushing that will deteriorate in time and cause sloppiness in the steering system. Replace those bushings with bushings made by "MOOG", these replacements are made of polyurethane and are blue in color, the steering will be much tighter, more responsive, and will wear much longer than the factory units. If you do it yourself, keep in mind there are washers between the bushings and the steering rack, do not loose them when removing the rod ends, the bushing kit does not provide a replacement washer, only the bushings and the bolt locking plate, and make sure those bolts are tight, they work loose and you can have some bad problems.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
