Old 07-30-2005, 05:25 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Any tips for removing a header?
My car has the 2.4L spyder engine. Since no one seems to make an aftermarket header for this car, I have decided to wrap the stock header. I have already ordered the suplies. I was just wondering if anyone has any tips on the easiest way to remove the header, because I have never done this before. And of course there is a little rust on the header and bolts. So what should I do? Should I just spray a can of WD-40 on the bolts and let it sit for a few minutes then try removing the bolts?
Thanks for the help!
Old 07-30-2005, 08:13 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Any tips for removing a header?
Spray a bunch of liquid wrench or wd-40 on the bolts. If the heat shield is on, loosen the bolts and make sure you can take off. Do this before the day you decide to do it. Gives you time to get everything ready. Break the bolts on the header before you decide to get it all done. If you have time, you don't need to put it all back together.
In short... loosen everything up. It's not too bad
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-30-2005, 08:29 PM
--- --- is offline
Pssst....check your PMs David.
I drive a slow car.
Old 07-30-2005, 08:40 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
I would soak the hell out of those bolts. Spray them a couple days before and spray them at night once your done driving this way they can soak over night. Good luck. Old bolts aren't fun.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 07-31-2005, 01:26 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
PB blaster works amazingly well at helping with rusted bolts, you should be able to get it at automotive stores
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-02-2005, 12:59 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
The real trick to it is PB blaster. Every night when you're done driving, soak them down and let it sit overnight. Oh, and let the manifold cool off first or you're just gonna burn off the PB blaster. Come game day, when loosening the bolts, loosen it, then tighten it a bit, then loosen again, and tighten a bit. This keeps everything in there from jamming up and stripping out threads. Continuous force just breaks shit. I learned this from a socket wrench and a breaker bar 2 weeks ago. I had to have 3 of the bolts at the base of the manifold retapped. Good luck!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
