Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-30-2005, 05:15 PM
noholdsbarred noholdsbarred is offline
Unhappy found the boost leak
I performed the boost leak test and found the leak around the intercooler outlet tube. Turns out there was so much corrosion between the tube and the rubber hose it caused 4 tiny holes on the outlet tube and lots of pitting on both pieces. The hose clamp won't cover the holes because they are too far down the tube. Would it be better to patch the holes with a weld or just replace everything? Has anyone ever seen this before?
2004 Impreza WRX
Old 07-30-2005, 05:16 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: found the boost leak
replace it ....not very expensive...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
