Old 07-30-2005, 04:49 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Rim Offset
what is the offset needed on a 4th gen? i found a site that sell corvette Z06 replicas gives 3 choices on the offset, 36mm, 56mm, and 58mm which one would be best? also could a 18x10.5 fit in the front with out rubbing?
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-30-2005, 08:33 PM
Re: Rim Offset
lol, no one knows? wdf... do you think that have a 10.5 rim up front would help with control / suspension / connering by having such a big area on the ground? or would it just be more problems then its worth? lol, i cant believe 18 ppl viewed this thread and not 1 response.
oh and the offset im talking about, is how much of an offset does the rim need so i dont need to use a spacer?
~Viper
Old 07-30-2005, 08:57 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I tried to figure this out about 5 years ago when one of my friends bought his ss, and the foregone conclusion between 4 of us was you can't go any wider than a 275/40/17 on the passenger side rear as with that tire (stock on the ss) you have about 1/2 inch of clearance between the tire and the fuel filler neck. I also believe the 18X10.5 will cause clearance issues in the front, unless you go with extremely low profile tires, basically wrap an elastic around the rim and watch out for potholes. Anyone else?
Old 07-31-2005, 08:27 PM
Re: Rim Offset
no idea what the offset is? i dont wanna use spacers...
~Viper
Old 07-31-2005, 08:36 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Probably have to, kinda like when 3rd gens want to use 4th gen rims on em, just gotta be done.
Old 07-31-2005, 08:54 PM
Re: Rim Offset
lol, if its a must then im gonna figure out how to get 10.5s upfront... lol, 10.5's will fit in the back tho right? the dude up a post or 2 said that it may make contact with the gas filler neck, so maybe that can be modifyed so i can get the rim in there?
~Viper
Old 07-31-2005, 10:10 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Rim Offset
9.5 is the widest you can go up front.
Old 07-31-2005, 10:35 PM
Re: Re: Rim Offset
lol, if you have to use spacers, why ot just use a spacer that makes the rim hang outside the fender well by an inch... just heat the fender up and pull it out a lil bit to cover the over hang of the tire (or custom fender flares)... there you go 10.5 up front.
~Viper
Old 08-01-2005, 01:13 AM
Genopsyde's Avatar
The President
Re: Rim Offset
http://thirdgen.org/techbb2/showthre...hreadid=312819
Old 08-01-2005, 06:17 AM
Re: Re: Rim Offset
that dont really tell me anything, thats about a 3rd gen. going wider with the axels is a good idea tho
~Viper
Old 08-01-2005, 07:30 AM
Re: Rim Offset
also, what about cutting out the inner fender wall and having new ones custom made? it would shrink the space of the engine bay by like 2 inches but it only really needs to be like 1 inch bigger on each side if 9.5 can fit i dont really see how 1 inch can make such a big diffrence that its imposible to do...
~Viper
Old 08-01-2005, 10:23 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Rim Offset
Any of them will fit w/o spacers.. 56mm is the one you want though..
You might have minor clearance issues upfront with the 18 X 10.5's couldnt tell you for sure though..
I had a bit of a time gettin mine to work properly.. Nothing a hammer didnt fix..
1991 Camaro Z28
Old 08-02-2005, 05:35 AM
Re: Re: Rim Offset
lol, the look of the rim stays the same right? with the off set? also i donno if you seen i am gonna have a 4th gen, i donno how much alike they are to 3rd gens, but i will deff get those damn 10.5s up front, even if i have to modify the inner fenderwall
~Viper
Old 08-02-2005, 05:50 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Re: Re: Rim Offset
Hmm, just not worth it IMO. 9.5's would work just fine for you. Otherwise you would just be adding unnecessary weight to the front end, which isn't exactly the best thing to do.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 08-02-2005, 06:03 PM
DaMoNe6969's Avatar
Well the rim itself stays the same.. where it sits in your fenderwell is what changes..The more of a positive offset the wheel has, the farther they will sink into the wheel well.. the less of an offset, the farther they will stick out.. As far as I know, the corvettes and the 4th gen camaros share a 56mm offset (or vary similar)
I know you were talking about a 4th gen, thats why I said I wasnt sure about clearance..
1991 Camaro Z28
