Old 07-30-2005, 03:04 PM
TealZ00 TealZ00 is offline
Tire Size
i know you guys have talked about tire size in here before but i cant find it in the search....If i got 30x11.50x15 swamper sx's would they fit on my stock 2000 chevy blazer 4x4 without having to lift it? or is there any chance 31's would fit
Old 07-30-2005, 05:55 PM
Re: Re: Tire Size
yeah but none of them talk about 30/11.50 15 they all say like9.5 is there anway 11.50 would fit stock and does anyone have any pics of their blazers with 30" tires
Old 07-30-2005, 07:57 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Tire Size
http://www.s10extremist.org/tech_art...ill_it_fit.htm
Take a look there and then disclose
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 07-30-2005, 08:26 PM
Re: Re: Tire Size
hey thanks a lot that really helped out a lot....the only other question i have is it says the 30's will fit but most people say 30x10.5 will fit fine i was wondering if anyone new if it would matter if they were 30x11.50...and they are thornbirds but if 31's fit stock the 30's with a little extra tread shouldnt matter
Old 07-30-2005, 10:02 PM
Re: Tire Size
Would not know for sure.I guess if you have to do some trimming it would not matter. That site also has alot of other technical things like tire size gear ratio and what not.I think blazee was the one who hooked me up with it first not positive
Old 07-31-2005, 04:09 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I can tell you right now that 31X10.5X15's will not fit without rubbing
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-01-2005, 12:05 AM
Re: Tire Size
yes they will...my best friend has a 98 blazer with 31x10.5.15`s on his stock blazer with not rubbing at all
Old 08-01-2005, 09:38 AM
Re: Re: Tire Size
I have a 98, I had 31's put on and the front tires rubbed. I was in the hop, sat down, turned the wheel myself and got out and saw where it was hitting. So I went with the 30's. If I cranked on the torsion bars they would fit but I did not want to play around.
K&N Air Filter
Old 08-01-2005, 10:34 AM
Re: Re: Re: Tire Size
ok so they will fit...u just didnt want to make them
Old 08-01-2005, 03:20 PM
Re: Re: Re: Re: Tire Size
I am "assuming" they will fit if I raise the front from stock height by cranking on the torsion bars which I don't want to do. The ride will suffer, you need an alignment after. Just not worth it to me.
K&N Air Filter
Old 08-01-2005, 04:11 PM
Re: Re: Re: Re: Re: Tire Size
o ok....i haev another question...is the zr2 just a 2" lift over the stock 4x4 ..or is it 3"
Old 08-01-2005, 04:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Tire Size
http://www.s10extremist.org/tech_art...comparison.htm
