Old 07-30-2005, 02:57 PM
mat3164 mat3164 is offline
radio console removal
Can someone tell me how to remove the climate control cable so i can remove my stock radio and reolace it with something better. I'm nervous about breaking it .
Old 07-31-2005, 10:27 AM
fantastimo fantastimo is offline
Send a message via AIM to fantastimo
I have not personally had my ESCORT apart around the climate control panel, but I have had many others to complete pieces including an olds alero I recently had to completely break down and detail (it was disgusting) and build back together. Every wiring harness I've ever seen has a clip that fits the two pieces together. If you're careful with the use of a flathead screwdriver, you should be able to get the two pieces apart without breaking anything. Just be easy, and if you see the plastic crease and turn white like it's about to break, observe the situation better. hope this helps.
Old 10-26-2005, 06:41 PM
TecChic's Avatar
TecChic TecChic is offline
Re: radio console removal
You can find an great description w/ pictures at
http://geocities.com/fordescortse2pt...ioremoval.html
I just recently installed a new cd player in my sister's car and was nervous about removing the climate control cable also!
Good Luck!!!
Old 10-26-2005, 08:48 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Re: radio console removal
Good Luck!!!
See my site for more info that may help
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
