Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-30-2005, 01:26 PM
monroe83 monroe83 is offline
Oil shooting from dip stick HELP ME
When I start my 1991 Caprice it runs fine but oil is constantly shooting out of my dip stick hole. I really need some help
Old 07-30-2005, 03:32 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Oil shooting from dip stick HELP ME
look at it directly with no glasses on with your eye directly above the hole with the car running, tell me what happens after
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 08-01-2005, 07:22 AM
V8Dime V8Dime is offline
Re: Re: Oil shooting from dip stick HELP ME
What a jerk of an answer.^
Check the little ball valve (PCV Valve) in the top of one of the rocker covers. If it's plugged, the blow by is escaping thru your dipstick tube.
YOU need a vaccum on the engine crankcase to pull the blowby out and that little rubber hose to the back of the carburator or intake manifold is it. Replace or clean out the hose and valve.
Also check and make sure the breather on the opposite cover is clean and open if there is one there.
Old 08-01-2005, 09:15 AM
1986Z28's Avatar
Has a Camaro
Re: Re: Re: Oil shooting from dip stick HELP ME
shut up noob, its called a joke
Old 08-01-2005, 10:08 AM
Re: Re: Re: Re: Oil shooting from dip stick HELP ME
Wow, another jerk "intelligent reply". Do you think those up all by yourself or do you get help?
Old 08-01-2005, 10:12 AM
alphalanos alphalanos is offline
If you arent going to contribute anything useful to the conversation then dont post. Its in the rules.
96 EJ6. Future home of boosted B18C1.
Old 08-02-2005, 06:21 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
First, make sure that the oil is not grossly over full. Then go with the PCV valve as someone else suggested. Then follow the line up to the manifold base to make sure it's not roasted, kinked or the base plate is gunked up. The next step is to pull the valve cover on the PCV side to see if the engine is sludged up. Which can open another bag of snakes for you. De-sludging an older motor can lead to major gasket leaks or the oil pump sucking up loosened sludge which often is full of grit and other undesirable contaminents.
Good luck, Bob
