Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 07-30-2005, 01:06 PM
susq susq is offline
Programming for garage door transmitter
Can someone please tell me how to program the transmitter for the garage door opener. If it matters, I have 96 Cadillac Deville
Old 08-02-2005, 11:44 AM
Houstonian Houstonian is offline
You have to set the dip switches in the new remote opener with the same settings of the dip switches on your garage door opener. This way they are matched and will work.
Old 12-31-2005, 12:26 AM
636neil 636neil is offline
Smile
You need to know if you have a rolling code garage door opener in your house first. If your controller in your car has a red light, it isn't rolling code adaptable. If you have a green light or orange light, you are good to go. The instructions should be in your owners manual to do this. They ar not hard but can be tricky.
Old 01-13-2006, 08:58 AM
autolady autolady is offline
If you have a newer garage door opener in the house it should program.
You have 3 buttons on the garage door opener in the car. Hold the outer buttons together until the yellow light flashes rapidly. That clears any old garage doors that were programmed, then chose which button you would like to open your garage door in the car. Hold your existing garage door opener transmitter to car buttons fairly close and push the buttons on both and hold until the yellow light flashes rapidly again. It should have programmed.
Old 01-13-2006, 02:13 PM
caddydaddy caddydaddy is offline
Re: Programming for garage door transmitter
Go to HomeLinks website. They will have detailed directions on how to program the remote opener.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
