I have a 94 intrepid 3.3L that runs like new until it gets warmed up. It still runs like a new car on the highway but when taking off from a stop it will stall. Put it in nuetral turn key of and then it starts right back up, but might do it 2 or 3 times after each stop, then you are good until you stop again. I have replaced the fuel pump, fuel filter,tps,crank sensor,map sensor,coil pod,wires,plugs,pvc valve,IAC valve,oxygen sensors,intake and plenum gaskets,cleaned the injectors and tested them.Fuel pressure is perfect, egr tested good,fuel pressure regulator checks out ok. The only thing that i havent changed is the cam position sensor and will do that today.I am stumped and very frustrated at this point and would appreciate any help . Also it has put out no error codes at all. when it happens it just dies as if someone turned the key off. yesterday for the first time it didnt want to start after it dies but finally did after about 20 minutes. HELP!!!!
Re: 94 intrepid 3.3L stals from stop only when hot!!
your ignition switch might also be faulty causing it to lose contact and making your engine stall.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
